  • Dayton Audio DNR-6.0 6 Ohm 10W Precision Audio Grade Resistor
Dayton Audio
Part #004-6
Dayton Audio
Part #004-6
Model: DNR-6.0
Dayton Audio DNR Series "Audio Grade" resistors are used in Zobel networks and fixed L-Pad attenuator circuits for tweeters. Nickel-chromium elements, a high thermal conductivity ceramic core, and welded construction all contribute to their low-noise performance.
Your Price: $1.10
MSRP: $2.99
Save $1.89 (63%)
Quantity:Qty: 1-9 $1.10/ea
Quantity:Qty: 10+$1.00/ea
1437In Stock
Dayton Audio DNR Series "Audio Grade" resistors are primarily used in Zobel networks and fixed L-Pad attenuator circuits. Nickel-chromium elements, a high thermal conductivity ceramic core, and welded construction all contribute to their low-noise performance. With a precision 2% tolerance, gold-plated oxygen free copper leads, and low-inductive wire wound construction, this resistor is a must for your next speaker crossover project! Dimensions: 48 mm L x 10 mm W x 10 mm H. Sold individually.
ModelDNR-6.0
Part Number004-6
UPC844632025778
Weight0.02
CompositionLow-Inductive Wirewound
Power Rating10W
Resistance
Tolerance2%
