  • Dayton Audio DNR-1.0 1 Ohm 10W Precision Audio Grade Resistor
Dayton Audio
Part #004-1
Dayton Audio
Part #004-1
Model: DNR-1.0
Dayton Audio DNR Series "Audio Grade" resistors are used in Zobel networks and fixed L-Pad attenuator circuits for tweeters. Nickel-chromium elements, a high thermal conductivity ceramic core, and welded construction all contribute to their low-noise performance.
Your Price: $1.05
MSRP: $2.99
Save $1.94 (65%)
Quantity:Qty: 1-9 $1.05/ea
Quantity:Qty: 10+$0.95/ea
Estimated back in stock 3/17/2025
Alert Me When Available
Dayton Audio DNR Series "Audio Grade" resistors are primarily used in Zobel networks and fixed L-Pad attenuator circuits. Nickel-chromium elements, a high thermal conductivity ceramic core, and welded construction all contribute to their low-noise performance. With a precision 2% tolerance, gold-plated oxygen free copper leads, and low-inductive wire wound construction, this resistor is a must for your next speaker crossover project! Dimensions: 48 mm L x 10 mm W x 10 mm H. Sold individually.
ModelDNR-1.0
Part Number004-1
UPC844632014062
Weight0.01
CompositionLow-Inductive Wirewound
Power Rating10W
Resistance
Tolerance2%
