  • Dayton Audio DC130BS-8 5-1/4" Classic Shielded Woofer
Dayton Audio
Part #295-301
Dayton Audio
Part #295-301
Model: DC130BS-8
Choose the Dayton Audio DC130BS-8 Classic Series 5-1/4" shielded woofer for use as a great replacement bookshelf speaker, midbass in 3-way designs, or even as a small subwoofer.
  • Great bang-for-the-buck driver can be used as a woofer, midbass, or even as a small subwoofer!
  • Smooth frequency response up to 2 kHz and great bass response
  • Rubber surround, aluminum voice coil, and extended bump plate
  • Shielded design increases performance and allows it to be used near tube TVs
Your Price: $26.98
MSRP: $33.99
Save $7.01 (21%)
Quantity:Qty: 1-3 $26.98/ea
Quantity:Qty: 4+$24.28/ea
Order in the next 2 hr 59 min to ship today. Details
Dayton Audio Classic Series woofers are excellent for use as replacement speakers or for new loudspeaker system design and construction. The DC130BS-8 5-1/4" woofer has developed quite a reputation for having the best bang-for-the-buck performance and value available anywhere. You can even use the DC130BS-8 as a small subwoofer! The excellent low frequency performance will amaze you.
A non-pressed treated paper cone allows for smooth frequency response, while the high temperature aluminum voice coil increases power handling without compression. Longevity is ensured with the use of a rubber surround, treated cloth dust cap, and an extended bump plate.
ModelDC130BS-8
Part Number295-301
UPC844632000225
Weight2.6
Nominal Diameter5-1/4"
Bolt Circle Diameter5.24
Power Handling (RMS)30 Watts
Power Handling (MAX)60 Watts
Frequency Response55 to 4,000Hz
Sensitivity88.9dB 2.83V/1m
Voice Coil Diameter1"
Resonant Frequency (Fs)50.5Hz
DC Resistance (Re)5.8Ω
Voice Coil Inductance (Le)0.82mH
Mechanical Q (Qms)1.82
Electromagnetic Q (Qes)0.49
Total Q (Qts)0.39
Compliance Equivalent Volume (Vas)0.31ft³
Mechanical Compliance of Suspension (Cms)1.13mm/N
BL Product (BL)5.71T·m
Diaphragm Mass Inc. Airload (Mms)8.8g
Surface Area of Cone (Sd)91.6cm²
Cone MaterialTreated Paper
Voice Coil FormerAluminum
Overall Outside Diameter5.71"
Baffle Cutout Diameter4.72"
Depth3.05"
Sealed Volume0.12ft³
Sealed F3118Hz
Vented Volume0.32ft³
Vented F350Hz
