  • Dayton Audio CFCOMBO-4MP 3/4" and 2" Carbon Fiber Tweeter/Mid Combo Matched Sets 4 Ohm
NEW Dayton Audio CFCOMBO-4MP 3/4" and 2" Carbon Fiber Tweeter/Mid Combo Matched Sets 4 Ohm
Dayton Audio
Part #285-412
Dayton Audio
Part #285-412
Model: CFCOMBO-4MP
The CFCOMBO-4MP matched pair midrange and tweeter set from Dayton Audio simplifies building 3-way systems in limited spaces, featuring frequency response-matched pairs of 3/4" carbon fiber dome tweeters and 2" carbon fiber dome midranges with compact yet powerful neodymium motors to ensure performance and reliability. Designed with truncated frames, the components can be positioned with a center-to-center distance of under 2-3/4", making them ideal for crossovers up to 5,000 Hz. This unique design is perfect for compact 3-way monitors, high-output center channels, and car stereo installations. The tweeters are matched to ±1 dB from 2,000 to 20,000 Hz. The midranges are matched to ±1 dB from 300 to 6,000 Hz.
  • Matched frequency response pairs ensure pinpoint imaging and accurate soundstage
  • Less than 2.75” center to center distance is ideal for crossovers as high as 5,000 Hz
  • Woven carbon fiber domes deliver accurate and detailed response
  • Powerful neodymium motors allow compact size without sacrificing performance
  • Rigid cast aluminum faceplates provide solid and air-tight mounting flanges
  • Integrated grills protect the domes from foreign objects and curious fingers
  • Compact size makes these perfect for small 3-ways, center channels, and car audio systems
NEW $199.98
MSRP: $299.99
Save $100.01 (33%)
Quantity:Qty: 1-3 $199.98/ea
Quantity:Qty: 4+$169.98/ea
The Dayton Audio CFCOMBO-4MP matched pair midrange and tweeter set brings exceptional sound quality and versatility to compact audio designs. Featuring frequency response-matched pairs of 3/4" tweeters and 2" midranges, this set is engineered to deliver pinpoint imaging and a precise soundstage, making it perfect for small 3-way monitors, high-output center channels, and car audio systems. With a center-to-center distance of less than 2.75", these components are optimized for crossovers as high as 5,000 Hz, ensuring seamless integration in any setup.
Matched pair tolerance:
Tweeter: ±1 dB from 2,000 to 20,000 Hz
Midrange: ±1 dB from 300 to 6,000 Hz
Premium Tweeter Design
The 3/4" carbon fiber dome tweeters feature woven diaphragms that produce detailed, accurate high frequencies with excellent off-axis response. Built with compact yet powerful neodymium motors, these tweeters maintain exceptional performance without taking up space. Ferrofluid-cooled voice coils enhance heat dissipation for improved power handling and reliability, while damped rear chambers minimize resonances for smooth, distortion-free output.
Durable cast aluminum faceplates provide structural stability, reducing vibrations that could impact sound quality, while integrated protective grills safeguard the delicate diaphragms from damage. These design elements make the tweeters a reliable choice for mobile audio setups, home audio systems, or any environment where space is limited but fidelity is essential.
Versatile Midrange Performance
The 2" carbon fiber dome midranges combine lightweight, rigid diaphragms with high-energy neodymium motors to deliver precise midrange response from a compact package. With smooth performance across a wide range of 500 to 6,000 Hz, these drivers are ideal for small 3-way designs and car audio applications. The cast aluminum faceplates reduce diffraction for consistent off-axis response, while integrated grills protect the domes from damage.
Engineered for reliability and efficiency, the midranges feature vented aluminum voice coil formers for superior heat dissipation and damped rear chambers to minimize internal reflections. Rubber surrounds further enhance performance by controlling unwanted resonances and maintaining diaphragm alignment.
Advanced Materials, Compact Design
The CFCOMBO-4MP set leverages advanced materials, including woven carbon fiber domes and rigid cast aluminum components, to ensure superior performance and longevity. Also, the high-energy neodymium motors keep the size as small as possible without sacrificing efficiency or reliability. Compact yet powerful, this set is tailored for audiophiles and installers who demand exceptional sound quality in space-constrained applications. To keep the drivers as close as possible the frames have segments removed allowing you to install the tweeter and midrange so the center-to-center distance is less than 2-3/4", perfect for crossovers as high as 5,000 Hz.
Whether you are designing high-fidelity home theater speakers, powerful center channels, or premium car audio systems, the Dayton Audio CFCOMBO-4MP midrange and tweeter set offers unmatched flexibility and performance in a compact form factor.
ModelCFCOMBO-4MP
Part Number285-412
UPC848791010637
Weight2.33
Cone MaterialWoven Carbon Fiber
Magnet MaterialNeodymium
