  • Dayton Audio BTR01 Bluetooth Audio Receiver with 24-bit/48 kHz Optical Coaxial RCA Outputs
CLEARANCE Dayton Audio BTR01 Bluetooth Audio Receiver with 24-bit/48 kHz Optical Coaxial RCA Outputs
Dayton Audio
Part #230-512
Dayton Audio
Part #230-512
Model: BTR01
The Dayton Audio BTR01 Bluetooth audio receiver provides you with Bluetooth wireless connectivity while retaining great sounding audio. With a variety of output options including analog stereo RCA, digital coaxial, and digital optical, the BTR01 gives you flexibly to integrate it into any audio setup. High sampling rates of up to 24-bit/48 kHz, the receiver gives you audiophile sound quality in a small, portable package.
  • Adds Bluetooth connectivity to any audio setup
  • Sample rates of up to 24-bit/48 kHz when used with coaxial or optical outputs
  • Analog and digital outputs for connecting to other audio devices such as active speakers, amplifiers, and home entertainment systems
  • Extended frequency response for uncompromised sound quality
  • Supports CSR true digital signal outputs and Hi-Fi lossless music playback
  • Package includes 12 VDC power adapter and Bluetooth antenna
Turn your current wired setup into a Bluetooth wireless enabled system with the Dayton Audio BTR01. Not only does the BTR01 give you the freedom of wireless connectivity, it also provides great sounding audio. Supporting CSR true digital signal outputs and Hi-Fi lossless music playback, the BTR01 truly delivers 24-bit/48 kHz (coaxial and optical outputs) audiophile sound quality. Easily integrated into your current playback system, the receiver's stereo RCA, optical, and coaxial outputs make this a great addition for any setup. Use the outputs to connect to any active speaker to other audio devices, such as an amplifier for passive speakers.
The lightweight aluminum alloy enclosure has an extremely small footprint making it inconspicuous and perfect for portable use. Since the BTR01 runs on 12v DC power it can easily be integrated into mobile audio systems commonly found in cars, boats, RV’s and even motorcycles. Easily upgrade old outdated audio systems with the BTR01.
  • Input: Bluetooth
  • Bluetooth version: 4.0
  • Output: Stereo RCA, optical, coaxial
  • Codec support: AAC
  • Sample rate: 16-24-bit/44.1-48 kHz (coax/opt)
  • Distortion rate: >0.004%
  • Frequency response: 20 - 20,000 Hz
  • SNR: 90 dB
  • DC power: 12V, 1A
  • Material: Aluminum alloy
  • Dimensions: 1.29" H x 3.85" W x 2.28" D
What Our Customers Love About The BTR01
Don't trust us... Here is what our customers have to say about the BTR01.
Bluetooth convenience and Dayton Audio quality in a modern upgrade to any analog sound system
"I was looking for a reasonably priced, good sounding, quick and easy way to find new music via Bluetooth from my iPhone. So, i saw this, bought it and connected it to my Cambridge Audio CXU universal DVD/DAC digital input ( digital output of the BTR01 goes into the CXU ) and the audio is upsampled giving a great warm sound on my HiFi system.
Since the module is so compact, it makes it easy for moving from my drum studio to garage or even outside! I'm also using it currently directly into a set of JBL LSR-305 powered studio monitors and they sound wonderful as well via the analog outputs.
The range is good for my needs. Once I get about 25-30 feet away things drop off, but that's the design of Bluetooth. NOT the BTR01. In summary, it's a great price and the Dayton quality we all have come to expect. It checked all of my boxes and it also SUPER easy to use and setup!"
ModelBTR01
Part Number230-512
UPC848791005169
Weight0.8
