  • Dayton Audio BTR02 Bluetooth 5.0 Audio Receiver With 24-BIT/48 KHZ APTX HD
Dayton Audio
Part #230-5120
Dayton Audio
Part #230-5120
Model: BTR02
The Dayton Audio BTR02 Bluetooth audio receiver allows for wireless connectivity without sacrificing audio quality. This compact receiver offers analog stereo RCA, digital coaxial, and digital optical output options, providing flexibility for integration with any audio system. With high sampling rates of up to 24-bit/48 kHz, the BTR02 delivers top-notch sound quality for audiophiles.
  • Adds Bluetooth connectivity to any audio setup
  • Sample rates of up to 24-bit/48 kHz when used with coaxial or optical outputs
  • Analog and digital outputs for connecting to other audio devices such as active speakers, amplifiers, and home entertainment systems
  • Extended frequency response for uncompromised sound quality
  • Supports APTX and Hi-Fi lossless music playback
  • Package includes 12 VDC power adapter and Bluetooth antenna
Your Price: $49.98
MSRP: $63.99
Save $14.01 (22%)
Estimated back in stock 4/30/2025
Alert Me When Available
Dayton Audio BTR02 Bluetooth Audio Receiver with 24-bit/48 kHz Optical Coaxial RCA Outputs
Turn your current wired setup into a Bluetooth wireless enabled system with the Dayton Audio BTR02. Not only does the BTR02 give you the freedom of wireless connectivity, it also provides great sounding audio. Supporting APTX HD, the BTR02 truly delivers 24-bit/48 kHz (coaxial and optical outputs) audiophile sound quality. Easily integrated into your current playback system, the receiver's stereo RCA, optical, and coaxial outputs make this a great addition for any setup. Use the outputs to connect to any active speaker to other audio devices, such as an amplifier for passive speakers.
The lightweight aluminum alloy enclosure has an extremely small footprint making it inconspicuous and perfect for portable use. Since the BTR02 runs on 12v DC power it can easily be integrated into mobile audio systems commonly found in cars, boats, RV’s and even motorcycles. Easily upgrade old outdated audio systems with the BTR02.
  • Input: Bluetooth
  • Bluetooth version: 5.0
  • Output: Stereo RCA, optical, coaxial
  • Codec support: AAC, APTX
  • Sample rate: 16-24-bit/44.1-48 kHz (coax/opt)
  • Distortion rate: >0.004%
  • Frequency response: 20 - 20,000 Hz
  • SNR: 90 dB
  • DC power: 12V, 1A
  • Material: Aluminum alloy
  • Dimensions: 1.29" H x 3.85" W x 2.28" D
ModelBTR02
Part Number230-5120
UPC848791008733
Weight0.8
