  • Dayton Audio BS41 41" LCR Speaker Bar Black
CLEARANCE Dayton Audio BS41 41" LCR Speaker Bar Black
Dayton Audio
Part #300-686
Dayton Audio
Part #300-686
Model: BS41
The Dayton Audio BS41 3-channel speaker bar delivers unexpected bass response in addition to smooth midrange and extended treble with dynamic range, setting it apart from its competition. As a result, the BS41 is one of the few speaker bars on the market that can replace larger bookshelf speakers and center channel speakers without compromise, and delivers the deepest bass without a subwoofer.
  • Designed for accurate reproduction of music and TV audio
  • Works with stereo, 5.1 or 7.1 receivers
  • Great alternative to large bookshelf or center speakers
  • Astonishing bass from high excursion 4" drivers
  • Use with or without a subwoofer
CLEARANCE $249.98
MSRP: $314.99
Save $65.01 (21%)
16In Stock
The Dayton Audio LCR speaker bar is designed to deliver bookshelf speaker sound, in a compact speaker bar configuration. A significant advantage of the BS41, compared to its speaker bar competition, is bass extension which resembles a pair of 6-1/2" full-range drivers, not the space-saving woofers in the BS41. Your friends will be looking for the subwoofer when this compact speaker bar is used on its own... without a sub.
When used with a medium to high powered 100 watts per channel AV receiver, the Dayton Audio BS41 plays louder with better bass and overall sound quality than the proliferation of anemically powered speaker bars found at the "Big Box" stores. Installation is simple; plug in the left, center, and right front-channel wires from the receiver to the left, center, and right push button terminals on the BS41.
If used with a subwoofer, set both AV receiver and subwoofer crossover to 80 Hz, this will blend nicely and maximize low distortion dynamic range. If no sub is used, the best compromise for bass extension and dynamic range is achieved with a 60 Hz receiver crossover setting. This will deliver all but the deepest bass, while maintaining room-filling, low distortion dynamic range and reliability.
Specifications: • Three 4" woofers • Three 5/8" tweeters • Power handling: 100 watts RMS/150 watts max • Impedance: 8 ohms • Frequency response: 50-22,000 Hz • SPL: 87 dB 1W/1m • Dimension: 5" H x 41" W x 3.8" D.
ModelBS41
Part Number300-686
UPC848791003967
Weight17.95
ColorBlack
ConfigurationMTM / LCR
Input Rating8 ohm
Woofer Diameter4"
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE 20%
Shadow Mounts DTS65 Universal Sturdy Desktop Tabletop Entertainment Center TV Monitor Stand Up to 65"
