  • Dayton Audio AS-1 AudioStrobe Woofer Analyzer Stroboscope
Dayton Audio
Part #390-814
Dayton Audio
Part #390-814
The Dayton Audio AS-1 AudioStrobe Woofer Analyzer Stroboscope was specifically designed with the loudspeaker enthusiast and professionals in mind. The typical frequency response of a loudspeakers contains peaks, nulls and/or resonances which are undesirable. The causes of such irregularities are difficult to see however by synchronizing the flashes per second at or near the frequency of the inputted sine wave to the loudspeaker, the loudspeaker seems motionless or in slow motion. This allows the loudspeaker behavior to be observed even in well-lit rooms thanks to 36 super bright LEDs with total output of 1000 lumens.
  • A " Must Have" tool for the speaker enthusiast or professional
  • Glow-in-the-Dark Buttons for use in dark environments
  • Large LCD with backlight for easy viewing
  • Super bright LED strobe (1000 lumens) is visible even in well-lit rooms
  • Single-step or continuous frequency tuning adjustment
  • Ergonomic ABS Plastic shell is solid and comfortable to operate
  • Memory storage for up to 10 sets of flash frequencies
Your Price: $59.98
MSRP: $99.99
Save $40.01 (40%)
By utilizing the phenomenon of persistence of vision, the Dayton Audio AS-1 can often help identify the cause of response defects and other useful information about individual drivers as well as complete loudspeaker systems by slowing down a driver's movement to see its performance in motion.
Dayton Audio’s AS-1 provides intermittent illumination of an object for visual analysis, up to a frequency of 665Hz. By adjusting the frequency of illumination, objects in vibrational or rotational movement can appear stationary or in slow motion. This optical illusion called visual persistence allows for a non-contact inspection and status of moving object surfaces well beyond the ability of the naked eye.
Watch the full instructional video
Hand-Held Diagnosis
The Dayton Audio AS-1 can help identify the cause of response defects and other useful information of individual drivers. These include, but are not limited to:
  • Non-linearity i.e. rocking motions of the cone
  • Cone, Surround and dust cap deformations
  • Resonance modes in spider and tinsel leads
  • Lead deformation
  • Spider deformation
  • Phase relationships in multi-speaker systems
  • Tuning frequency and behavior of passive radiators
  • Excursion limits of active and passive drivers
Large Readout
The illuminated screen lets you see important information while using the AS-1 in the dark.
Glow-in-the-dark Buttons
Glowing buttons allow you to make changes to the output while using the AS-1 in the dark.
Ultra-Bright LEDs
Ultra-Bright LEDs illuminate the object in motion so the visual effect of the AS-1 is reliable
Slow Motion
The Dayton Audio AS-1 Audiostrobe was specifically designed with the loudspeaker enthusiast and professionals in mind. The typical frequency response of a loudspeaker contains peaks, nulls, and/or resonances that are undesirable. The causes of such irregularities are difficult to see however by synchronizing the flashes per second at or near the frequency of the inputted sine wave to the loudspeaker, the moving components appear motionless or in slow motion.
We Got Your Back
Learn More
Shop All Speaker Building Tools!
Shop Audio Analyzers for audio testing & measuring at Parts Express.
Omnimic V2
Dayton Audio's OmniMic V2 is a must-have omnidirectional acoustic measurement system for audio system integrators, acoustic engineers, and residential A/V installers.
Shop Now
DATS V3
DATS V3 is a unique, multipurpose test system to measure the impedance response of a speaker driver and derive a complete set of T/S parameters.
Shop Now
IMM-6
Turn any phone or tablet with a 3.5 mm jack into a laboratory grade audio measurement device with Dayton Audio's iMM-6 iDevice calibrated measurement microphone.
Shop Now
UMM-6
Dayton Audio's UMM-6 USB measurement microphone matches the level of precision previously offered only by expensive measurement equipment.
Shop Now
ModelAS-1
Part Number390-814
UPC848791008139
Weight0.9
