  • DataComm 45-0002-UWH 2-Gang Recessed Low Voltage Cable Plate
NEW DataComm 45-0002-UWH 2-Gang Recessed Low Voltage Cable Plate
DataComm Electronics
Part #261-5401
Model: 45-0002-UWH
Install low voltage cables behind your flat panel TV, your amplifier or other audio/video devices, flush to the wall surface with this two gang recessed bulk cable wall plate. Cable management is hidden inside the wall for a neat, clean, and custom look.
  • Used by CEDIA custom installers
  • Patent pending design hides cables behind wall mounted equipment
  • Perfect partner for home theater systems
NEW $6.99
MSRP: $9.99
Save $3.00 (30%)
Order in the next 3 hr 52 min to ship today. Details
It's understandable to want the cleanest installation possible for A/V equipment, for yourself or your customers. A flat TV mount can make for a stunning display, but the question becomes where to put the wires. A recessed bulk cable wall plate is a versatile, inobtrusive solution for hiding situations in which a traditional, single-purpose wall plate won't fit.
Fits all standard two-gang low-voltage installation rings.
Note: A low voltage mounting bracket is needed to install this wall plate. See related items for the appropriate bracket.
BrandDataComm Electronics
Model45-0002-UWH
Part Number261-5401
Weight1.2
