  • DataComm 60-0022-S Dual Gang Low Voltage Mounting Bracket
Read 1 Review or
DataComm Electronics
Part #261-506
Model: 60-0022-S
Read 1 Review or
DataComm's low voltage mounting brackets are designed to retrofit existing construction to mount cable plates flush against the wall. The non-conductive plastic material is perfect for TV, computer, audio, and communications wiring in applications where a low voltage pass through is necessary.
  • Non-conductive material
  • Adjustable fit for 1/4" to 1" thick drywall
  • Quick and easy installation process
  • Mounting tabs to fasten the bracket
  • Dual gang size
Your Price: $2.33
MSRP: $2.99
Save $0.66 (22%)
Order in the next 5 hr 46 min to ship today. Details
The DataComm low voltage mounting bracket is designed for installations on existing construction. The open back design allows for easy installation, leaving room for the depth of volume controls, as well as speaker wiring. The bracket also serves as its own template for cut outs. It is adjustable to fit 1/4" to 1" thick drywall. The mounting tabs fasten to the drywall as the mounting screws are tightened for a secure fit. For use with low voltage wiring only.
BrandDataComm Electronics
Model60-0022-S
Part Number261-506
UPC660559015339
Weight0.1
