  • DS18 GEN-X6.5C 6-1/2" 2-Way Component Speaker System Pair 4 Ohm
CLEARANCE DS18 GEN-X6.5C 6-1/2" 2-Way Component Speaker System Pair 4 Ohm
DS18
Part #294-8022
DS18
Part #294-8022
Model: GEN-X6.5C
The GEN-X6.5C 2-way component speaker pair from DS18 features 6-1/2" treated paper cone woofers, 1-1/2" silk dome tweeters, optimized outboard passive crossovers, and sleek mesh grills with red accents. These unique speakers will hit all frequencies with great accuracy and high SPL. They boast a fine clarity that is unparalleled by any other speaker in their price range.
  • 6-1/2" damped paper cone woofers with stitched rubber surround delivers natural response
  • 1-1/2" silk dome tweeters produce accurate high frequencies with low distortion
  • Standard size woofer for an easy drop-in installation in many factory mounting locations
  • Flush mount bracket for the tweeters to easily optimize audio at the listening position
  • Included grills offer protection with a modern look
  • High performance audio for an exceptional value
DS18's GEN-X6.5C 2-way 6-1/2" component speaker pair combines a 6-1/2" paper cone woofers, 1-1/2" silk dome tweeters, and optimized passive crossover networks for natural full-range response with low distortion. A naturally damped paper cone woofer minimizes unwanted resonances to deliver powerful low frequency response and high impact midbass. The durable rubber surround is securely stitched to cone to ensure a reliable bond even when exposed to high excursion in the extreme automotive environment. High frequencies separate 1-1/2" soft dome tweeters that offers high efficiency, accuracy, and wide dispersion. The included flush mount bracket makes it easy to install the tweeters into any flat surface allowing you to easily aim the tweeters for optimum perfromance. With good efficiency and capable of handling up to 50 watts RMS the GEN-X6.5C will produce impressive output even when driven with modest power.
With a standard size and various mounting points, the GEN-X6.5C woofer is a direct drop-in upgrade for many vehicles. You can expect clarity, detail, durability, and output that is unmatched by other speakers in this price range.
Note: Grills, speaker wire, crossovers and mounting hardware included
Type: 6-1/2" 2-way component system
Woofer: 6-1/2" damped paper cone
Tweeter: 1-1/2" silk dome
Power handling: 50 watts RMS (150 watts max)
Frequency response: 76-20,000 Hz
Sensitivity: 86 dB 1W/1m
Impedance: 4 ohms
Voice coil (woofer): 1" diameter
Basket structure (woofer): Stamped steel
Mounting depth (woofer): 2.25"
Outside diameter (tweeter): 2.5"
BrandDS18
ModelGEN-X6.5C
Part Number294-8022
UPC663593064011
Unit of MeasurePairs
Weight5.75
Speaker Size6.5"
Power Handling (RMS)50 Watts
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
