  • DS18 G6.9Xi 6"x9" 3-Way 180W Coaxial Speaker Pair 4 Ohm
1 Question, 2 Answers or
DS18
Part #294-8020
DS18
Part #294-8020
Model: G6.9Xi
The G6.9Xi 6" x 9" 3-way coaxial speaker pair from DS18 features dual Mylar balanced dome tweeters, black paper cone woofers with rubber edges, and sleek mesh grills with red accents. These unique speakers will hit all frequencies with great accuracy and high SPL. They boast a fine clarity that is unparalleled by any other speaker in their price range.
  • 6" x 9" damped paper cone with stitched rubber surround delivers natural response
  • 1-1/8" and 3/4" Mylar balanced tweeters produce accurate high frequencies with low distortion
  • 1-1/8" andStandard size for an easy drop-in installation in many factory mounting locations 3/4" Mylar balanced tweeters produce accurate high frequencies with low distortion
  • Standard sIncluded grills offer protection with a modern lookize for an easy drop-in installation in many factory mounting locations
  • High performance audio for an exceptional value
Your Price: $63.95
Order in the next 6 hr 47 min to ship today. Details
DS18's G6.9Xi 9 6" x 9" 3-way coaxial speaker pair combines a paper cone woofer and dual Mylar tweeters for natural full-range response with low distortion. A naturally damped paper cone woofer minimizes unwanted resonances to deliver powerful low frequency response and high impact midbass. The durable rubber surround is securely stitched to cone to ensure a reliable bond even when exposed to high excursion in the extreme automotive environment. High frequencies are handled by 1-1/8" and 3/4" balanced drive Mylar tweeters that offers high efficiency, accuracy, and wide dispersion. With good efficiency and capable of handling up to 60 watts RMS the GEN-X6.9 will produce impressive output even when driven with modest power.
With a standard size and various mounting points, the GEN-X6.9 is a direct drop-in upgrade for many vehicles. You can expect clarity, detail, durability, and output that is unmatched by other speakers in this price range.
Note: Grills, speaker wire, and mounting hardware included
Type: 6" x 9" 3-way full range
Woofer: 6" x 9" damped paper cone
Tweeters: 1-1/8" and 3/4" Mylar dome
Power handling: 60 watts RMS (180 watts max)
Frequency response: 65-20,000 Hz
Sensitivity: 87 dB 1W/1m
Impedance: 4 ohms
Voice coil: 1-1/4" diameter
Basket structure: Stamped steel
Mounting depth: 3"
BrandDS18
ModelG6.9Xi
Part Number294-8020
UPC663593064004
Unit of MeasurePairs
Weight6.4
Speaker Size6"
Power Handling (RMS)60 Watts
MONSTER DEAL
OF THE WEEK
$129.49 EACH
SAVE $14
Dayton Audio HTA20 20 Watt Integrated Stereo Hybrid Tube Amplifier With USB-DAC and Bluetooth 5.0
