DS18 CANDY-X5B CANDY 5-Channel Compact Full-Range Class D 2000W AmplifierThe DS18 CANDY-X5B CANDY 4-Channel compact Full-Range Class D 1600W amplifier is the perfect amplifier for people who want a very small footprint and all the benefits that come from larger amplifiers by putting out lots of power in a small package.
The CANDY-X5B can be set up to power full range speakers, subwoofers, and tweeters with it's built in crossovers and adjustable crossover points. Two independent crossovers allow for the ability to power different sets of speakers between the amplifier's first four outputs. Additionally, the CANDY-X5B is designed to power a subwoofer on channel 5 with independent phase control and an included remote volume control knob.
With 120 watts RMS of power per channel at 2 ohms, 80 watts RMS of power per channel at 4 ohms, and 240 watts RMS of power per channel pair when operated at 4 ohms bridged, the CANDY-X5B delivers ultimate power and control
Power output at 4 ohms: 4 x 80 watts RMS + 1 x 200 watts RMS
Power output at 2 ohms: 4 x 120 watts RMS + 1 x 230 watts RMS
Power output at 4 ohms bridged: 2 x 240 watts RMS + 1 x 200 watts RMS
Frequency Response: 20 Hz - 20 kHz
Total harmonic distortion: 0.01%
Signal-to-noise ratio: 100dB
Dimensions: 280 mm x 127 mm x 47.5 mm (11.02" x 5" x 1.87")
