  • DS18 SLC10S Select 10" Paper Cone Subwoofer 4 Ohm
DS18
Part #294-8076
DS18
Part #294-8076
Model: SLC10S
The Select series SLC10S 10" paper cone subwoofer from DS18 is perfect for customers who are looking for sound quality and output on a budget. To ensure reliable performance the specially treated foam surround is stitched to the rigid non-pressed paper cone creating a mechanical bond that will last and last. Excess heat from the 2" 4-layer voice coil is vented through the frame and motor assembly for high power handling and low power compression. The SLC10S is ideal for anyone looking to upgrade their car audio system without breaking the bank.
  • Powerful motor and high excursion capability for excellent low frequency output
  • 2" diameter 4-layer voice coil handles up to 220 watts RMS (440 watts max)
  • Glass reinforced paper cone with stitched foam surround for long life and durability
  • Venting under the spider and though the motor dissipates excess heat to keep the voice coil cool
  • Push button wire terminals make connections simple and secure
Your Price: $84.95
Only 2 In Stock
For car audio enthusiasts on a budget, DS18's SLC10S 10" paper cone subwoofer driver is a great way to add some powerful low end to your system without breaking the bank. An oversized treated foam surround is mechanically stitched to the fiberglass reinforced paper cone to ensure that that high stress joint will not fail even under high excursion and stress. To handle up to 220 watts RMS, the SLC10S uses a 2" 4-layer voice that is thoroughly vented through the pole piece and under the spider which dissipates excess heat and minimizes power compression. Push button spring loaded terminals are used to provide a simple and secure wire connection for easy installation. Optimized for use is sealed and infinite baffles designs, this rugged driver is overbuilt to reliably deliver excellent low frequency response for years.
BrandDS18
ModelSLC10S
Part Number294-8076
UPC663593056511
Weight8.75
Nominal Diameter10"
Bolt Circle Diameter9.68
Power Handling (RMS)220 Watts
Power Handling (MAX)440 Watts
Frequency Response40 to 4,500Hz
Sensitivity88dB 2.83V/1m
Voice Coil Diameter2"
Resonant Frequency (Fs)40Hz
DC Resistance (Re)3.6Ω
Mechanical Q (Qms)5.88
Electromagnetic Q (Qes)0.89
Total Q (Qts)0.774
Compliance Equivalent Volume (Vas)1.3ft³
Maximum Linear Excursion (Xmax)8.5mm
Surround MaterialFoam
Voice Coil FormerAluminum
Overall Outside Diameter10.23"
Baffle Cutout Diameter9.13"
Depth4.45"
Sealed Volume1ft³
Sealed F347.8Hz
Vented Volume1.25ft³
Vented F337.2Hz
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
