  • Clear Acrylic Mounting Plate for TPS3116D2 Class D 2.1 Bluetooth 4.0 Amplifier Board
Part #320-634
Part #320-634
This clear acrylic mounting plate makes it easy to install the TPS3116D2 class D 2.1 Bluetooth amplifier board into any project. At 3 mm thick, this plate is designed to support the weight of the amplifier without any additional bracing. Each knob has a label etched into the front of the plate for easy identification. This mounting plate with the TPS3116D2 2.1 Bluetooth amplifier board is perfect for your next portable Bluetooth speaker project.
  • Makes it easy is install the TPS3116D2 class D 2.1 Bluetooth amplifier board
  • Thick and rigid construction for a solid installation
  • Pre-labeled knobs for easy identification
  • Clear plate can be painted on the back side for custom colors and a glass-like finish
Your Price: $13.98
MSRP: $20.99
Save $7.01 (33%)
Quantity:Qty: 1-9 $13.98/ea
Quantity:Qty: 10+$12.58/ea
Order in the next 13 hr 10 min to ship today. Details
This 6-1/2" x 3" clear acrylic mounting plate is designed specifically for use with the TPS3116D2 class D 2.1 Bluetooth amplifier board . Every knob is labeled for easy identification and the power/pairing LED on the amplifier board is visible through the clear plate. At nearly 1/8" thick and with 8 mounting points, this mounting plate is capable of supporting the full weight of the amplifier by the knobs without the need for additional bracing. In addition, thanks to the clear construction, you can paint the back side to create any custom color you desire resulting in a glass-like finish.
Part Number320-634
UPC848864056319
