  • Celestion CDX1-1425 Neo 1" Compression Horn Driver 25W
Celestion
Part #294-2132
Celestion
Part #294-2132
Model: CDX1-1425
Celestion high frequency drivers are a popular OEM component -- many loudspeaker system manufacturers are incorporating transducers like the CDX1-1425 into their designs.
  • 1" exit neodymium compression driver with 1.4" copper clad aluminum voice coil
  • 25 watts RMS power handling and 108 dB sensitivity
  • Copper sleeve on pole reduces inductive rise for improved HF performance
  • Ferrofluid in magnet gap prevents sensitivity loss through thermal compression
  • Aluminum diaphragm combined with elastomer surround delivers lower distortion performance
  • Finite Element Analysis (FEA) used to optimize both magnet and acoustic design
  • Suitable for 2-way and 3-way systems, and line arrays
Your Price: $115.00
MSRP: $172.50
Save $57.50 (33%)
Estimated back in stock 12/27/2024
Alert Me When Available
The Celestion CDX1-1425 is a leading example of the emerging class of ultra-compact neodymium high frequency drivers. The CDX1-1425's minimal size makes it ideal for the spacing constraints of professional line array systems as well as very small 2-way and 3-way loudspeakers.
Specifications: • Power handling: 25 watts RMS (AES standard) • Recommended min. crossover: 2,500 kHz, 12 dB/octave • VCdia: 1.4" • Impedance: 8 ohms • Frequency response: 2,000-20,000 Hz • Sensitivity: 108 dB 1W/1m • Mounting (flange): 2 x M6 holes on 3" PCD • Dimensions: 3.5" dia. x 2.3" depth • Net weight: 0.9 lbs.
BrandCelestion
ModelCDX1-1425
Part Number294-2132
UPC739894534444
Weight1
Diaphragm MaterialAluminum
Exit Diameter1"
Mounting Type2-Bolt
Power Handling (RMS)25 Watts
MONSTER DEAL
OF THE WEEK
$129.49 EACH
SAVE $14
Dayton Audio HTA20 20 Watt Integrated Stereo Hybrid Tube Amplifier With USB-DAC and Bluetooth 5.0
