  • Dayton Audio HTA20 20 Watt Integrated Stereo Hybrid Tube Amplifier With USB-DAC and Bluetooth 5.0
Dayton Audio
Part #300-3846
Dayton Audio
Part #300-3846
Model: HTA20
The HTA20 is a 20-watt Class A/B amplifier that features amber toned pre-amp tubes that provide a warm sound, making it a perfect addition to any music enthusiast's setup. A built-in sub out allows you to add low-end to your music. The built-in USB DAC lets you easily connect your computer audio to your external speakers, and Bluetooth 5.0 allows you to connect your phone or tablet for wireless streaming. For those who prefer to listen in private, the quick and easy headphone connection provides a convenient option. With the HTA20, you'll enjoy high-quality sound with a refined look.
  • 20 Watt Class A/B amplifier with amber-toned preamp tubes for a warm sound
  • Sub Out to connect external subwoofers for added low-end
  • Built-in USB DAC for direct connection to computers
  • Conveniently placed headphone output for private listening
  • Bluetooth 5.0 allows you to stream your favorite music from a phone or tablet
Your Price: $154.98
MSRP: $199.99
Save $45.01 (23%)
Order in the next 2 hr 34 min to ship today. Details
The perfect solution to bring the rich sound of a tube amplifier to your home audio setup; the innovative design of the HTA20 combines the best of both worlds – the classic sound of vintage tube-style amplifiers and the modern convenience of a solid-state amplifier. This amplifier offers great value for money, so you can get the classic Hi-Fi sound you've been dreaming of, without breaking the bank.
A Contemporary Classic
Debates may rage between whether solid-state or tube amplifiers produce a better listening experience; however, Dayton Audio solves the debate. By harnessing the best qualities of both, Dayton Audio's HTA20 hybrid tube amplifier utilizes the classic design of a class A/B amp topology while employing vacuum tubes in the preamp circuit. The tubes' subtle character and warmth create a delightful homage to the classic valve amplifiers of the past.
Flexibility & Power
With an RMS output power rating of 15 watts per channel at 4 ohms, the HTA20 packs a serious punch perfect for almost any home audio listening system. The added convenience of Bluetooth 5.0 ensures that your wireless streaming has the best possible quality and functionality.
Connected Versatility
Rear-mounted analog inputs allow more permanent connections to larger input sources. Complete with a dedicated phono input, USB DAC, and a subwoofer output, the HTA20 allows you to integrate all your equipment to enjoy the classic sound of tube equipment.
  1. Bluetooth Antenna Port
  2. Auxiliary RCA Inputs
  3. PC USB Input Port
  4. Preamp Subwoofer Output (Full Range)
    1. Powered Speaker Outputs
    2. Power On/Off Switch
    3. AC Power Input
      All Backed By A 5-Year Warranty
      • Power output: 15 WPC RMS @ 4 ohms
      • THD: <0.5% @ 15 WPC RMS
      • Minimum speaker impedance: 4 ohms
      • SNR: 75 dB
      • Frequency response: 20-20,000 Hz
      • Sub output: Full-Range pre-amplifier output
      • Bluetooth: Version 5
      • Supports Bluetooth codecs: SBC and AAC
      • Power: 110/220 VAC, 50/60 Hz Standard IEC Connection
      • Fuse Rating (120v): 5x20mm 5AL
      • Dimensions: 6.5" x 11" x 8.5"
      • Preamplifier Tubes: 6F1 x 2
      ModelHTA20
      Part Number300-3846
      UPC848791009013
      Weight3.6
