  • Dayton Audio H812 1" Exponential Horn 100x60 2-Bolt
Dayton Audio
Part #270-304
Dayton Audio
Part #270-304
Model: H812
The Dayton Audio H812 horn is engineered to operate smoothly down to the lowest possible crossover frequency, while maintaining consistent and predictable dispersion throughout its intended range.
  • Exponential flare for improved throw and better on-axis HF response
  • Glass-reinforced polycarbonate construction
  • Mounting flange for 2-bolt 1" drivers
  • 100&#176 H x 60&#176 V coverage
  • Useable to 800 Hz
Your Price: $19.98
MSRP: $28.99
Save $9.01 (31%)
Quantity:Qty: 1-3 $19.98/ea
Quantity:Qty: 4+$17.98/ea
Dayton Audio horns are engineered to operate smoothly down to the lowest possible crossover frequency, while maintaining consistent and predictable dispersion throughout their intended range. The H812 employs a traditional exponential flare that provides improved throw and better HF response, but with narrowing dispersion at the highest frequencies. The horn is precision molded from glass-reinforced polycarbonate, and has a flange for mounting 1" bolt-on style drivers.
Specifications: • Lowest recommended crossover frequency: 800 Hz • Nominal coverage: 100° H x 60° V • Dimensions: 7-7/8" H x 12-1/2" W x 8-1/8" D.
ModelH812
Part Number270-304
UPC844632009198
Weight1.8401
ConstructionPolycarbonate
Entry / Throat Diameter1"
Mounting Type2-Bolt
