  • C-Note MT Bookshelf Speaker Kit Pair with Knock-Down Cabinets
Part #300-7140
Part #300-7140
Model: C-Note MT
How do you build great sounding speakers on a budget? Easy! The C-Note bookshelf speaker kit delivers accurate response, incredible imaging, and a surprising amount of bass -- all for an unbeatable price! Nearly everything is included to complete this speaker building project: a pair of knock-down cabinets, drivers, port tubes, and crossover components, crossover circuit boards, binding posts, screws, and wire.
  • Accurately reproduces music as the artists intended it to be heard
  • Pinpoint imaging with a wide soundstage for an immersive listening experience
  • Simple instruction manual makes anybody a speaker builder instantly
  • Customize the C-Note to your personal tastes -- finishing options are limitless
  • CNC cut MDF enclosures are easy to assemble with minimal tools
  • Now includes printed circuit boards for easy crossover assembly and installation
Your Price: $139.98
MSRP: $224.00
Save $84.02 (38%)
Order in the next 3 hr 10 min to ship today. Details
The C-Note speaker kit delivers a lot more than the price and size suggests. We have done everything to keep costs down without sacrificing quality. This compact speaker pair provides extremely flat response with much lower end than you would expect from a speaker this small. In addition, the C-Note’s controlled dispersion delivers pinpoint imaging with a surprisingly wide soundstage.
Features:
Customer Comments:
"Simply unbelievable. The detail and imaging is mind-blowing" - Ryan ⋆⋆⋆⋆⋆
"They sound fantasic and I’m shocked by the amount of bass..."- Peter M. ⋆⋆⋆⋆⋆
"These sound better than many pre-assembled speakers in $300 dollar range." -Exporter ⋆⋆⋆⋆⋆
"First time building diy speakers. Had a lot of fun with my 11 year old son." -Lourenço C ⋆⋆⋆⋆⋆
Customer Projects:
The Cabinet
The C-Note speaker kit delivers a lot more than the price and size suggests. We have done everything to keep costs down without sacrificing quality. This compact speaker pair provides extremely flat response with much more low end than you would expect from a speaker this small. In addition, the C-Note's controlled dispersion delivers pinpoint imaging with a surprisingly wide soundstage.
The solid MDF enclosure's 1/2" panels are all CNC milled to tight tolerances, ensuring easy assembly. The surface mounted woofer is easy to install, while the flush mounted tweeter provides a sleek appearance.
The Drivers
Dayton Audio's DSA135-8 5" Designer Series woofer is used for the midrange and low frequencies. With an aluminum cone and a powerful motor designed for low distortion, this woofer produces bass with authority while remaining smooth through the midrange frequencies. The high frequencies are handled by the ND25FW-4 1" soft dome tweeter , also from Dayton Audio. This waveguide-loaded tweeter controls high frequency dispersion for smooth off axis response and natural sound. Another advantage of the waveguide design is that it allows the voice coil to set further back from the baffle for an almost perfect time alignment with the woofer.
The Crossover
Dividing the frequencies between the drivers is a 6 component 2-way crossover network. Polypropylene caps, air core inductors, and low inductance resistors are used, allowing this network to pass audio with minimal effect to the original signal. The C-Note kit now includes dual sided printed circuit boards making the crossover assembly and installation easier than ever.
Kit Components:
Part #QTY.Description
295-5262Dayton Audio DSA135-8 5" Designer Series Aluminum Cone Woofer
275-051
2Dayton Audio ND25FW-4 1" Soft Dome Neodymium Tweeter with Waveguide 4 Ohm
027-4232Dayton Audio DMPC-5.1 5.1uF 250V Polypropylene Capacitor
027-4144Dayton Audio DMPC-2.0 2.0uF 250V Polypropylene Capacitor
027-4242Dayton Audio DMPC-6.8 6.8uF 250V Polypropylene Capacitor
004-62Dayton Audio DNR-6.0 6 Ohm 10W Precision Audio Grade Resistor
257-0262Dayton Audio AC20-25 0.25mH 20 AWG Air Core Inductor Coil
257-0512Dayton Audio AC201-4 1.4mH 20 AWG Air Core Inductor Coil
260-3882Port Tube 1-3/8" ID Adjustable
101-2596ftAudtek 16 AWG Stranded OFC Twisted Pair Speaker Cabinet Hookup Wire Red/Black 1 ft.
081-423225-Pack #6 x 3/4" Pan Head Deep Thread Black Screws
080-9420.1Cable Ties 12" Black 100 Pcs.
091-1245
2Dayton Audio BPA-38G HD Binding Post Pair Gold
-1C-Note Bookshelf Speaker Kit Knock-Down Enclosure Pair
Assembly Instructions:
Easy to follow step-by-step instructions walk you through the painless assembly process. In a matter of hours, you can assemble the kit which makes the C-note a great introduction into the speaker building world. The kit includes all the components needed to build an amazing sounding, portable speaker. Some standard tools are required to assemble the enclosure.
  • Power: 60 Watts RMS/120 Watts Max
  • Tweeter: 2 x Dayton Audio ND25FW-4 1" Soft Dome Neodymium Tweeter with Waveguide 4 Ohm
  • Woofer: 2 x Dayton Audio DSA135-8 5" Designer Series Aluminum Cone Woofer
  • Frequency response: 43-20,000 Hz
  • Impedance: 8 Ohm
  • Sensitivity: 85 dB 1W/1m
  • Dimensions: 11" H x 7.5" W x 9.5" D
ModelC-Note MT
Part Number300-7140
UPC848864044354
Weight21
Cabinet Dimensions (HxWxD)11" x 7.5" x 9.5"
Cabinet OptionsUnfinished/Unassembled
ColorUnfinished
Configuration2-way
Input Rating8 ohm
Speaker TypeBookshelf
Woofer Diameter5"
