  • C-Note Center Channel Speaker Kit
Part #300-7142
Part #300-7142
Model: C-Note Center
Ideal for completing your budget DIY home theater system, the C-note center channel speaker features natural vocal reproduction with the output capability and dynamics needed to meet the demands of today's movie soundtracks. Nearly everything is included to complete this DIY speaker building project: a knock-down cabinet, drivers, port tubes, crossover components, and hardware.
  • Designed to provide lifelike vocal response with smooth high frequency response
  • High output capability to deliver the dynamics necessary for movie sound tracks
  • Simple instruction manual makes anybody a speaker builder instantly
  • Customize the C-Note center channel to your personal tastes - finishing options are limitless
  • CNC cut MDF enclosure is easy to assemble with minimal tools
Your Price: $134.98
MSRP: $213.18
Save $78.20 (37%)
Order in the next 4 hr 31 min to ship today. Details
Designed to be teamed up with the popular C-note bookshelf speaker, the C-note MTM center channel speaker kit makes it simple to build your own high quality home theater system for an unbeatable value. Voiced to match the sound of the C-note bookshelf speaker, this center channel has improved output capability and dynamics that are necessary to meet the demands of today's movie soundtracks. In addition, special attention was taken with the crossover design to keep any sibilance under control, ensuring no listener fatigue after long sessions at high output. This easy to assemble center channel give you the opportunity to complete your own home theater system with a finish that matches your own personal tastes and décor.
Features:
  • This kit includes nearly everything you need to build a top-notch center channel speaker in no time flat, including: a knock-down enclosure, drivers, crossover components, binding posts, screws, and wire.
  • Customize the C-Note to your personal tastes -- finishing options are limitless
Customer Comments:
"I enjoyed assembling the speaker, and I have a great sounding center channel. Zero disappointments, for this first time assembler." -Kidd W ⋆⋆⋆⋆⋆
" I just got mine working and it sounds great. I'm a budget type guy and replaced my current center a Pioneer sp-c22. This speaker sounds cleaner and has a noticeably better low end, it still blends okay with my Pioneer towers." - Samuel Y ⋆⋆⋆⋆⋆
" Awesome sound. " -Karl K ⋆⋆⋆⋆⋆
Customer Projects:
The Woofers
Two of Dayton Audio's DSA135-8 5" Designer Series woofers are used for the midrange and low frequencies. With aluminum cones and powerful motors designed for low distortion, these woofers produces bass with authority while remaining smooth through the midrange frequencies.
The Tweeters
The high frequencies are handled by the ND25FW-4 1" soft dome tweeter , also from Dayton Audio. This waveguide-loaded tweeter controls high frequency dispersion for smooth off axis response and natural sound. Another advantage of the waveguide design is that it allows the voice coil to set further back from the baffle for an almost perfect time alignment with the woofer.
Kit Components:
Part #QTY.Description
295-526
2Dayton Audio DSA135-8 5" Designer Series Aluminum Cone Woofer
275-051
1Dayton Audio ND25FW-4 1" Soft Dome Neodymium Tweeter with Waveguide 4 Ohm
004-3
1Dayton Audio DNR-3.0 3 Ohm 10W Precision Audio Grade Resistor
004-20
1Dayton Audio DNR-20 20 Ohm 10W Precision Audio Grade Resistor
027-418
1Dayton Audio DMPC-3.0 3.0uF 250V Polypropylene Capacitor
027-432
2Dayton Audio DMPC-15 15uF 250V Polypropylene Capacitor
027-416
1Dayton Audio DMPC-2.7 2.7uF 250V Polypropylene Capacitor
027-454
1Dayton Audio DFFC-0.22 0.22uF 400V By-Pass Capacitor
257-020
1Dayton Audio 0.10mH 20 AWG Air Core Inductor Crossover Coil
257-050
1Dayton Audio 1.2mH 20 AWG Air Core Inductor Crossover Coil
260-388
2Speaker Cabinet Port Tube 1-3/8" ID Adjustable
091-1245
1Dayton Audio BPA-38G HD Binding Post Pair Gold
081-423
125-Pack #6 x 3/4" Pan Head Deep Thread Black Screws
-116 AWG 2-conductor Power Speaker Wire 4 ft. (Red/Black)
-1C-Note MTM Center Channel Kit Knock-Down Enclosure
  • Power: 80 watts RMS/160 watts max
  • Frequency response: ±3 dB from 43-20,000 Hz
  • Impedance: 4 Ohm
  • Sensitivity: 87 dB 1W/1m
  • Dimensions: 8" H x 21.5" W x 9.5" D
ModelC-Note Center
Part Number300-7142
UPC848864057071
Weight18.76
