  • Blast Box 200 Watt Portable Bluetooth Speaker Kit
Part #300-7162
Part #300-7162
Model: Blast Box
Portable, powerful, and fun… The easy to assemble Blast Box portable Bluetooth wireless speaker kit allows you to take high output, Hi-Fi sound with you wherever you go. The 2.1 channel design, capable of 200 watt RMS, uses a pair of 3" aluminum cone woofers and 1" titanium tweeters with a single 6-1/2" high excursion subwoofer. This compact package produces crystal clear midrange and highs with incredibly powerful bass response.
  • High power 5 driver system delivers amazing depth, clarity, detail, and output
  • Perfect for picnics, parks, tailgating, yard work or anywhere you want great sound
  • Onboard controls allow you to easily customize the sound for any environment
  • Designed for excellent off-axis performance, ideal for large open areas
  • High quality Baltic birch plywood enclosure is rugged and easy to assemble
  • Includes everything needed to build the kit and step-by-step manual makes assembly easy
Your Price: $299.98
MSRP: $499.96
Save $199.98 (40%)
Out of Stock
Estimated back in stock 4/25/2025
Dayton Audio Blast Box 200 Watt Portable Bluetooth Speaker Kit
Features:
  • High-quality Baltic birch plywood enclosure is rugged and easy to assemble
Customer Comments:
"Will never be mistaken for a typical boombox as its just too loud and the bass is so big." -Warrior Drum ⋆⋆⋆⋆⋆
"Very clean sound. The bass really thumps." -quick573 ⋆⋆⋆⋆⋆
"Kit was fun to build... Deep bass, good midrange imaging and clear highs..."-Michael S. ⋆⋆⋆⋆⋆
"Great kit, probably the best sounding portable speaker i heard in a long time." -Mrrich ⋆⋆⋆⋆⋆
Customer Projects:
Kit Components:
Part #QTY.Description
320-6351TPS3116D2 Class D 2.1 Bluetooth 5.0 Amplifier Board 2 x 50W + 100W with Filter and Volume Controls
295-198
1Dayton Audio DCS165-4 6-1/2” Classic Subwoofer 4 Ohm
295-4921Dayton Audio DS215-PR 8” Designer Series Passive Radiator
325-2011Dayton Audio LBB-3v2 3 x 18650 Lithium Battery Charger Board/ Module 12V with Charge Protection
275-0572Dayton Audio ND25TA-4 1” Titanium Dome Neodymium Tweeter
295-5222Dayton Audio DSA90-8 3” Designer Series Aluminum Cone Full-Range Driver 8 Ohm
004-82Dayton Audio DNR-8.0 8 Ohm 10W Precision Audio Grade Resistor
257-0482Dayton Audio 1.0mH 20 AWG Air Core Inductor Crossover Coil
257-0202Dayton Audio 0.10mH 20 AWG Air Core Inductor Crossover Coil
027-412
2Dayton Audio DMPC-1.5 1.5uF 250V Polypropylene Capacitor
027-420
4 Dayton Audio DMPC-3.3 3.3uF 250V Polypropylene Capacitor
142-103
1 Lishen 18650 2600mAh Li-Ion Flat Top Battery 3-Pack
-1 Blast Box 1/2" thick high quality Baltic birch plywood enclosure
All necessary hardware, hook-up wire, binding posts, power adaptor, gasket tape included
Note:
  • Crossover components may be substituted with parts of equal or higher quality depending on available inventory.
  • Batteries not included with part number 300-7163. You will need 3 x 18650 Li-Ion batteries for proper operation.
  • Power: 2 x 50 watts RMS + 1 x 100 watts RMS
  • Tweeter: 2 x ND25TA-4 1" titanium dome tweeter
  • Midrange: 2 x DSA90-8 3" aluminum cone full-range
  • Subwoofer: 1 x DCS165-4 6-1/2" high excursion subwoofer
  • Frequency response: 35 – 20,000 Hz
  • Battery Time: 8 - 10 Hours at moderate volume
  • Bluetooth version: 4.0
  • Dimensions: 12" H x 16" W x 6" D
ModelBlast Box
Part Number300-7162
UPC848864056395
Weight19.85
Cabinet Dimensions (HxWxD)12" x 16" x 6"
Cabinet OptionsUnfinished/Unassembled
ColorUnfinished
Configuration2.1 System
Input RatingPowered
Speaker TypePortable Bluetooth
Woofer Diameter6.5"
