  • Behringer NX6000D Ultra Lightweight Class D 6000W Power Amplifier with DSP
CLEARANCE Behringer NX6000D Ultra Lightweight Class D 6000W Power Amplifier with DSP
Behringer
Part #248-7017
Behringer
Part #248-7017
Model: NX6000D
Packing 6000W into a lightweight chassis, the Behringer NX6000D Class D amplifier delivers thundering, efficient power. The ultra-efficient design runs much cooler than conventional amplifier counterparts. Built-in DSP and high-performance 24-bit/96kHz converters give you the ability to tailor your sound with delay, crossovers, EQ, dynamics processing, and lockable security settings. Featuring SmartSense Loudspeaker impedance compensation, the NX6000D provides fully linear frequency response at any speaker load impedance.
  • Delivers 6000W of power packed into a lightweight, rack-mountable chassis
  • Cool-running high-density Class D technology with "near-zero" thermal buildup for the ultimate reliability
  • High-performance DSP and converters featuring delay, crossover frequency, EQ, dynamics processing, and lockable security settings
  • Ultra-efficient power supply for noise-free audio, superior transient response, and low power consumption
  • Features a built-in crossover with low and high cut as well as full range
  • SmartSense Loudspeaker impedance compensation for fully linear frequency response at any speaker load impedance
  • "Zero-Attack" limiter provides maximum output with a reliable overload protection
Providing seemingly effortless power to your rig, the Behringer NX6000D Class D power amplifier has the ability to drive the most demanding systems. The 6000W NX6000D power amplifier runs much cooler than counterparts by employing an ultra-efficient power supply. In addition to a reliable, efficient amp, the NX6000D's feather-light rack-mountable chassis provides the ultimate portability.
Featuring Class D amplifier technology, the NX6000D provides enormous power and excellent sonic performance while remaining lightweight, easy to use, and ultra-portable. High-density Class D amplification eliminates the need for power supplies and delivers highly efficient output. Not only are the NX6000Ds lighter in weight than counterparts, they also use less energy while retaining extremely powerful output.
The NX6000D comes equipped with high-performance, high-functionality digital signal processing (DSP) for the engineer that requires high-level control capability. The built-in DSP and 24-bit/96kHz converters provide the ultimate signal integrity and broad dynamic range. The DSP section features sophisticated delay, crossover (3 filter types, up to 48 dB/octave), EQ (8-band parametric, 2-band dynamic EQ), dynamics processing, and lockable security settings. The DSP functionality is easily accessed via a front panel LCD amber display with backlights.
Don't worry about overloading your system with the built-in "Zero-Attack" limiter which ensures maximum output without overloads. Behringer's SmartSense Technology provides a detailed full-range frequency response with powerful, dynamic bass and silky high-frequency response. The technology ensures the output is not dependent on the actual load of the speakers and produces a flat response via impedance compensation. Incorporating a higher damping factor, the NX6000D yields better amplifier control over the speakers for stronger audio reproduction.
With a glance monitor the vial signs of the NX6000D. The front panel controls and indicators make monitoring signal extremely easy. Each channel features positive-detent gain controls with signal and limit LEDs to provide real time output feedback. The back panel features combo XLR and 1/4" TRS combo input jacks making the NX6000D compatible with both unbalanced and balanced sources. Professional twist lock speakon type connectors ensure a secure connection to loudspeakers.
The amp can be ran in dual mono, stereo, or mono bridge modes. The built-in crossover also provides you with the ability to set the amp as a full-range output or as a bi-amp output featuring high and low cut filters.
Supporting massive power in a lightweight chassis, the NX6000D carries an equally lightweight price tag. With all the power and amenities that the professional audio engineer needs, the Behringer NX6000D power amplifier performs exceptionally for the most demanding applications.
Specifications: • Power output: 2 x 3000W @ 4 ohms, 2 x 1600W @ 8 ohms • Input impedance: 10K ohms (unbalanced), 20k ohms (balanced) • Outputs: 2 x speakon type connectors • Output circuit type: Class D • Distortion: <0.2% Bull; Frequency response: 20 - 20,000 Hz • Signal to noise: >100 dB • Cooling: Continuously variable speed fan • Amplifier protection: Thermal and DC protection • Power supply: 120V, 60 Hz • Power consumption: 620W @ 4 ohms, 1/8 rated power • USB Connection: Type B (on back) • Dimensions: 3.7" H x 19" W x 9.1" D.
BrandBehringer
ModelNX6000D
Part Number248-7017
UPC653341314833
Weight15.85
Output Channels2
Weight Range10 to 19 lbs.
