  • B&C DE10-8 1" Mylar Horn Compression Driver 8 Ohm 2-Bolt
B&C Speakers
Part #294-600
B&C Speakers
Part #294-600
Model: DE10-8
The B&C Speakers DE10-8 1" high frequency compression driver features a low mass Mylar diaphragm and optimized ceramic magnet assembly, which allow high sensitivity and low distortion up to 18 kHz.
  • Low mass Mylar diaphragm for smooth, non-fatiguing output
  • Aluminum voice coil
  • Very high sensitivity and smooth response
  • Compact yet powerful FEA-optimized ceramic ferrite magnet structure
Your Price: $52.88
MSRP: $88.13
Save $35.25 (40%)
B&C's DE10-8 1" high frequency compression driver is small and efficient, yet does not sacrifice fidelity. Its smooth, brilliant output extends to 18,000 Hz, and is accurate yet non-fatiguing. The DE10-8 is perfect for compact 2-way loudspeaker systems, as well as the tweeter component in larger 3-ways. Although engineered to excel in demanding pro audio environments, the DE10 is also the choice of many home audio high-efficiency speaker enthusiasts.
Specifications: • Power handling: 20 watts RMS/40 watts program above recommended crossover of 2.5 kHz/12 dB slope • VCdia: 1" • Impedance: 8 ohms • Frequency response: 1,500-18,000 Hz • SPL: 107 dB 1W/1m • Dimensions: 3.5" diameter x 2.1" depth • Net weight: 1.8 lb. • Replacement diaphragm available.
B&C Speakers' line of compression drivers is the result of a continuous research effort, dedicated to refine every component in the structure, and their overall balance. Diaphragms are made of titanium, or mylar, or both, in order to get the required results in efficiency and bandwidth. Their shape and structure is mathematically evaluated well before building the first prototype. Afterwards, their performance is tested with methods that range from modal analysis to laser vibrotomy.
All voice coils are of the edgewound ribbon type, and made of aluminum to reduce mass and achieve the best electro-acoustic performance. The magnet assembly is designed and optimized with up-to-date software for Finite Element Analysis (FEA) and complemented, where needed, by a copper cap to improve frequency extension and linearity. Equal care is taken in the design of phase plugs, whose role in enhancing performance and reducing distortion artifacts is critical for compression drivers. The precision and transparency of B&C compression drivers is constantly improved by the progress in acoustical modeling and simulation.
BrandB&C Speakers
ModelDE10-8
Part Number294-600
UPC844632001734
Weight1.75
Diaphragm MaterialPoly / Mylar
Exit Diameter1"
Mounting Type2-Bolt
Power Handling (RMS)20 Watts
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
