  • Audtek 100 ft. 10 AWG OFC Speaker Wire
Audtek Electronics
Part #100-029
Model: SKRL-10-100
Audtek Electronics' SKRL speaker wire is designed to complement any high-end audio system. Features a clear, flexible PVC insulation and OFC configured in a rope-lay configuration to minimize skin effect. 10 AWG, 100 ft spool.
  • 413 x 36 AWG wire construction
  • OFC strands guarantee maximum power transfer and high damping factor
  • High-density rope lay copper stranding for superior flexibility and electrical efficiency
  • Durable, pliable clear PVC insulation withstands abuse
  • Extremely low capacitance and inductance
  • Red line on one conductor and ridge on the other for easy polarity identification even in low light
Your Price: $114.98
MSRP: $159.99
Save $45.01 (28%)
Quantity:Qty: 1-3 $114.98/ea
Quantity:Qty: 4+$109.98/ea
Estimated back in stock 4/30/2025
Alert Me When Available
Audtek Electronics' SKRL speaker wire is designed to complement any high-end audio system. Oxygen free copper (OFC) is configured in a rope-lay configuration to minimize skin effect which causes high frequency roll-off. Clear, flexible PVC insulation withstands abuse and is rated up to 140°F (60°C). Red line on one conductor and ridge on the other for easy polarity identification even in low light. Construction: 413 strands x 36 AWG per conductor. Also available in 50 and 250 ft. rolls and 12, 14, and 16 AWG.
Audtek uses pure copper strands in its OFC speaker wire. You'll see OFC (Oxygen Free Copper) in many places which means the copper strands go through an additional process making it more than 99% pure copper and the result reduces resistance which increases conductivity. Increasing conductivity delivers more wattage/current to speakers or other components.
Available at a lower cost is CCA (Copper Clad Aluminum) speaker wire, which is aluminum strands covered by a thin layer of copper. Pure copper's conductivity is 35% to 40% better than CCA due to the resistance that aluminum strands add to the signal transfer. That means you would have to buy a larger gauge of CCA wire to get the same result as OFC wire. CCA wire is also very hard to get good solder results when making your own cables. Even in premade cables, the wires are more likely to separate from the connectors and cause intermittent failures. This is why we strongly recommend Audtek OFC wire and cable for all you hookup needs.
BrandAudtek Electronics
ModelSKRL-10-100
Part Number100-029
UPC844632055393
Unit of MeasureRolls
Weight10
Conductors2 Conductor
Jacket ColorClear
Wire Gauge10
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
