  • Audio-Technica ATH-M50xBT2 Professional Studio Monitor Headphones with Bluetooth
Audio-Technica
Part #242-4531
Audio-Technica
Part #242-4531
Harnessing the legendary sound and performance of the ATH-M50x studio sound, the Audio-Technica ATH-M50xBT2 add the added convenience of Bluetooth, touch controls, and mic for calls. The exhilarating wireless listening experience of exceptional clarity and deep, accurate bass make the ATH-M50xBT2 the perfect set of headphones not only for studio use but also for everyday personal use.
  • Wireless, on-the-go design delivers the same critically acclaimed sonic performance as the original ATH-M50x professional studio headphones
  • Proprietary 45 mm drivers and dedicated amplifier deliver exceptional clarity and deep, accurate bass response
  • Buttons built into the earcup provide easy control of volume/mute, music, and calls, and give you access to your voice assistant
  • Sidetone circuitry improves conversations by letting you hear your voice in the headphones when making calls on most smartphones
  • Professional-grade earpad and headband material for long-lasting durability and comfort
  • Compatible with high-quality LDAC and AAC codecs
  • Up to 50 hours of continuous use on a full charge and up to 3 hours of use on a 10-minute rapid charge (via USB-C connection)
Your Price: $199.00
ATH-M50xBT2 Wireless Over-Ear Headphones
The ATH-M50xBT2 represents the second generation of Audio-Technica’s acclaimed M-Series wireless over-ear headphones. These headphones feature 45 mm large-aperture drivers in a wireless design, maintaining the legendary sonic signature of the original ATH-M50x studio headphones. This updated version introduces several enhanced features, including improved vocal pickup for clearer calls, an upgraded USB-C connection, and a convenient multipoint pairing mode.
Whether you need high-fidelity audio for your daily commute, a reliable conference call setup, or simply a way to enjoy your favorite music wirelessly, the ATH-M50xBT2 is designed to meet your needs. Leveraging Bluetooth technology, these headphones deliver the same studio-quality sound as their wired counterpart, with deep, accurate bass and immersive audio. The AK4331 advanced audio DAC and built-in headphone amplifier further elevate sound clarity and fidelity, ensuring a superior listening experience.
Equipped with dual microphones and beamforming technology, the ATH-M50xBT2 offers crystal-clear call quality and easy muting with a dedicated button. Users can also access voice assistants like Amazon Alexa, Google Assistant, and Siri directly through the headphones. With an impressive battery life of up to 50 hours on a full charge and 3 hours of use from just a 10-minute rapid charge via USB-C, these headphones are among the longest-lasting in their class.
The multipoint pairing feature allows seamless connection to two Bluetooth devices simultaneously, making it effortless to switch between tasks. Personalize your experience using the A-T Connect app, which lets you activate low latency mode, adjust and save EQ settings, balance left/right volume, select your preferred voice assistant, and more. The ATH-M50xBT2 combines advanced features with the trusted performance of Audio-Technica’s M-Series, offering a versatile solution for modern wireless listening.
  • Type: Closed-back dynamic
  • Driver Diameter: 45 mm
  • Frequency Response: 15 - 28,000 Hz
  • Sensitivity: 99 dB
  • Battery: DC 3.7V lithium polymer battery
  • Battery Life: Approx. 50 hours continuous use
  • Weight: Approx. 307g
  • Charging Time: Approx. 3.5 hours
  • Microphone Type: MEMS type
  • Microphone Sensitivity: -38 dB (1V/Pa at 1 kHz)
  • Microphone Frequency Response: 85 -15,000 Hz
  • Microphone Polar Pattern: Omnidirectional
  • Accessories Included: USB charging cable(30cm、USB Type-A / USB Type-C), Audio cable (1.2m/ φ3.5mm stereo mini-plug), Pouch
  • Bluetooth® Version: Bluetooth Ver.5.0
  • Operating Range: Line of sight – approx. 10 m (33′)
  • Compatible Bluetooth Profiles: A2DP, AVRCP, HFP, HSP
  • Support Codec: LDAC / AAC, SBC
BrandAudio-Technica
ModelATH-M50xBT2
Part Number242-4531
UPC4961310145965
Weight1.8
ColorBlack
Fit StyleOver-the-Ear
Type or Typical UseHi-Fi / Portables
Special FeaturesBluetooth / Wireless-Device Control-Foldable Collapsible-Microphone-Volume Control
