  • Audio-Technica AT-LP70X-BG Fully Automatic Belt-Drive Turntable
NEW Audio-Technica AT-LP70X-BG Fully Automatic Belt-Drive Turntable
Audio-Technica
Part #240-5704
Audio-Technica
Part #240-5704
Model: AT-LP70X-BG
The Audio-Technica AT-LP70X-BG Fully Automatic Belt-Drive Turntable offers a high-quality vinyl listening experience for both beginners and audiophiles. With fully automatic operation, it plays 33-1/3 and 45 RPM records with ease, featuring a built-in phono preamp for flexible connectivity to stereo systems or powered speakers.
  • A fixed-body AT-VM95C Integral Dual Moving Magnet™ phono cartridge is compatible with any VM95 Series replacement stylus
  • Stylish three-piece chassis construction dampens resonance for improved sound quality
  • Tonearm lock reduces risk of stylus damage
  • J-shaped tonearm is engineered to minimize tracking errors
  • Anti-resonance, die-cast aluminum platter with felt mat
  • AC adapter handles AC/DC conversion outside of the chassis, reducing noise in the signal chain
  • Includes detachable RCA output cable (dual RCA male to dual RCA male with ground), 45 RPM adapter, and removable hinged dust cover
NEW $199.00
Order in the next 0 hr 58 min to ship today. Details
The Audio-Technica AT-LP70X-BG Fully Automatic Belt-Drive Turntable offers an impressive combination of convenience, style, and audio performance, making it a great choice for vinyl enthusiasts at any level. Its fully automatic operation allows users to simply press a button to play records at either 33-1/3 or 45 RPM speeds. The AT-VM95C Dual Moving Magnet™ cartridge, pre-mounted on an AT-HS3 headshell, delivers high-quality sound with crisp, clear audio reproduction, providing an upgrade over basic cartridges. This cartridge is also compatible with other VM95 series replacement styli, giving users flexibility to experiment with different audio profiles.
The AT-LP70X-BG features a robust anti-resonance, die-cast aluminum platter, which helps minimize unwanted vibrations during playback, resulting in clearer and more precise sound. This is further enhanced by the three-piece chassis construction that adds additional dampening properties for improved sound fidelity. The built-in switchable phono preamp offers great versatility, allowing users to connect the turntable directly to a wide range of audio systems, whether they have a dedicated phono input or not.
Complete your setup! The AT-LP70X can be connected to Audio-Technica’s AT-SP3X powered bookshelf speakers for an easy-to-manage sound system that fits in any room and requires no external amplifier. Rest easy knowing your turntable and speakers were made to go together.
For users who value ease of use without compromising on sound quality, the fully automatic design is ideal, simplifying operation with its start and stop functions. Combined with the elegant aesthetics and sophisticated build quality, the AT-LP70X-BG blends seamlessly into modern or vintage setups alike. Whether you're just starting your vinyl collection or looking to enhance your audio system, this turntable offers a reliable, versatile solution with features designed to elevate your listening experience.
  • Motor: DC motor
  • Drive Method: Belt drive
  • Speeds: 33-1/3 RPM, 45 RPM
  • Turntable Platter: Die-cast aluminum
  • Wow and Flutter: < 0.25% (WTD)
  • Signal-to-Noise Ratio (SNR): > 55 dB
  • Cartridge Type: AT-VM95C Dual Moving Magnet Stereo Cartridge. The cartridge cannot be removed.
  • Output Level:
    -PHONO: 4.0 mV nominal at 1 kHz, 5 cm/sec
    -LINE: 252 mV nominal at 1 kHz, 5 cm/sec
  • Phono Pre-Amp Gain: 36 dB nominal, RIAA equalized
  • Effective Arm Length: 220 mm (8.7")
  • Overhang: 18 mm (0.71")
  • Tracking Error Angle: Less than 2.0°
  • Replacement Stylus: AT-VMN95C (sold separately)
  • Replacement Belt: AT-LP70X exclusive belt (sold separately)
  • Power Consumption: 1.5 W
  • Dimensions: 400 mm (16") × 330 mm (13") × 110 mm (4.3") (W × D × H)
  • Weight: Approx. 2.9 kg (6.4 lbs)
  • Accessories Included
    • Dust cover
    • Felt mat
    • Platter (with drive belt)
    • Dust cover hinges
    • 45 RPM adapter
    • RCA audio cable (Approx. 1.0 m (3.3'))
    • AC adapter (Approx. 1.5 m (4.9'))
  • AC Adapter:
    •Type: FJ-SW1261200500DN
    •Rated Input Voltage: 100 to 240 V AC
    •Rated Input Current: 0.4 A max.
    •Rated Frequency: 50 Hz / 60 Hz
    •Rated Output Voltage: 12 V DC
    •Rated Secondary Current: 0.5 A
    •Cable Length: Approx. 1.5 m (4.9')
BrandAudio-Technica
ModelAT-LP70X-BG
Part Number240-5704
UPC4961310162191
Weight6.5
