  • Audtek Premium Dual 6 ft. RCA Turntable Cable with External Ground Wire
Audtek Electronics
Part #181-966
Model: DMCG6
Replace your defective, too short, or low-quality turntable cables with Audtek premium 6 ft. dual shielded patch cable. This cable has an attached ground wire which older magnetic cartridge turntables must have. Gold plated RCA connectors with metal shell and oxygen-free copper stranded center conductor give it a professional look and delivers second-to-none performance.
  • 24 AWG stranded oxygen-free copper center conductor for better signal transfer
  • Braided shielding over Mylar foil provides maximum shielding
  • Highly flexible PVC jacket
  • Durable metal shell for extra shielding all the way to the tip
  • Gold-plated connectors resist oxidation for long lasting performance
  • Attached ground wire for magnetic cartridge turntables
Your Price: $7.98
MSRP: $9.98
Save $2.00 (20%)
274In Stock
Most turntable manufacturers throw in a short 3 ft., cheaply built cable to quickly hookup your turntable to an amplifier/receiver. These cables have a hard time reaching the rest of your components in a home theater or stereo rack. If the cable does reach, you might experience a humming sound or outside interference with its partially braided shielded wire. Audtek Electronic's premium 6 ft. dual shielded cable design with professional looking metal shells prevents this from happening, plus is long enough for most installs. Use the attached ground wire to prevent noise when hooking up a magnetic cartridge turntable into the phono jack on an amplifier/receiver.
Audtek's 24 AWG Oxygen-Free Copper (OFC) stranded center conductor and gold-plated connectors increase the signal strength over those super-thin thrown in cables. Patch cables that come with most turntables have very thin 30 to 32 AWG center conductors. Manufacturers save even more money by using Copper Covered Aluminum (CCA) strands that decrease your signal strength even more than thin gauge conductors. CCA strands also cause weak solder joints which leads to disconnects from the connector. Tin platted connectors over time corrode which also causes a disconnect from your amplifier/receiver. Audtek plates its connectors with gold to prevent this from happening. Audtek designs its turntable cable to deliver a clean, long-lasting signal providing enjoyable music for years to come.
BrandAudtek Electronics
ModelDMCG6
Part Number181-966
UPC848864071602
Weight0.4
Cable Length6feet
Cable TypeRCA Male to Male
Jacket ColorBlack
    MONSTER DEAL
    OF THE WEEK
    $19.98 EACH
    SAVE $10
