  • Atlas Sound PD60AT 60W 70V Horn Driver
Atlas Sound
Part #242-856
Atlas Sound
Part #242-856
Model: PD60AT
Competitively priced PD Series compression drivers provide accurate sound reproduction, optimum intelligibility, and dependable performance in commercial sound, high-power music, and PA loudspeaker systems.
  • Environment-resistant construction for indoor/outdoor use
  • Extended frequency range for optimum intelligibility
  • Die-cast housing finished in gray baked epoxy
Your Price: $286.99
MSRP: $355.99
Save $69.00 (19%)
Competitively priced PD Series compression drivers provide accurate sound reproduction, optimum intelligibility, and dependable performance in commercial sound, high-power music, and PA loudspeaker systems. The integral 70V line-matching transformer is varnish impregnated for maximum environment resistance and life expectancy, and incorporates a screwdriver selectable tap/watts selector switch. It also includes a protective terminal cover with built-in strain relief to assure secure cable connection. Standard 1-3/8"-18" thread male coupling for use with screw-on horns.
Specifications: • Power rating: 60 watts • 70.7V Taps: 2.5, 5, 10, 20, 40, 60 watts • Frequency response (plane wave, ±5 dB): 300-3,700 Hz • Low frequency limit (at full power): 300 Hz • SPL (±5 dB): 112.7 dB • Dimensions: 6-3/8" dia. x 6-7/8" D • Mfg. #PD60AT.
BrandAtlas Sound
ModelPD60AT
Part Number242-856
UPC612079161713
Weight9
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
