  • Atlas Sound CJ-46 Wide Angle Reflex Horn 120 x 60
Atlas Sound
Part #242-852
Atlas Sound
Part #242-852
Model: CJ-46
The all-purpose CJ-46 is a low silhouette directional horn for sound and signaling installations where wide-area dispersion and maximum sound and audibility are required. Dimensions: 22" W x 12" H x 17" L.
  • Directional high-efficiency reflex sound projector with 120° x 60° wide-angle dispersion
  • Environment-resistant construction for outdoor / indoor applications
  • Equipped with standard 1-3/8"-18 female threads for use with screw-on compression drivers
  • Heavy-duty positive locking steel mounting bracket for secure positioning
Your Price: $224.99
MSRP: $279.99
Save $55.00 (20%)
The Atlas Sound CJ-46 low silhouette directional horn is ideal for sound and signaling installations where wide-area dispersion and maximum sound and audibility are required. Recommended for use with compression driver units in indoor and outdoor applications that include community warning systems, sports and leisure facilities, industry, and commerce. Mounting bracket for horizontal, vertical, or stacked positioning is heavy-duty steel with positive lock. Manufactured of non-resonant fiberglass finished in black with a spun aluminum re-entrant section. Low-end cut-off: 115 Hz. Dimensions: 22" W x 12" H x 17" L.
BrandAtlas Sound
ModelCJ-46
Part Number242-852
UPC612079111527
Weight14.5
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
