  • Atlas Sound GA-15T 15W Utility Paging Horn Speaker
Atlas Sound
Part #242-846
Atlas Sound
Part #242-846
Model: GA-15T
The GA Series utility horns are perfectly suited for voice paging and music transmission. • 70.7V Taps: 1, 2, 4, 8, 15 watts • Nominal frequency response: 400-6,000 Hz • Sensitivity: 103 dB 1W/1m
  • Dual voltage, knob-adjustable impedance selection for 25/70.7V line connection
  • Multi-function, re-entrant horn loudspeakers offer efficient sound penetration
  • Sturdy construction for long-term indoor and outdoor paging, music, and intercom use
Your Price: $82.99
MSRP: $100.99
Save $18.00 (18%)
The GA Series utility horns are perfectly suited for voice paging and music transmission. Double re-entrant horn construction optimizes loudspeaker output to penetrate ambient sound levels. Includes a combination 25/70.7 volt line transformer with multi-position knob switch for selecting power taps and wiring for an 8 ohm connection. GA Series models are constructed of weather resistant, high-impact plastic for indoor/outdoor installations in high-humidity environments and feature an adjustable surface mount bracket. Gray finish with silver colored hardware.
Specifications: • Power rating: 15 watts • 70.7V Taps: 1, 2, 4, 8, 15 watts • Nominal frequency response: 400-6,000 Hz • Sensitivity: 103 dB 1W/1m • Dimensions: 7-1/2" dia. x 9-3/8" L x 10" H • Mfg. #GA-15T
BrandAtlas Sound
ModelGA-15T
Part Number242-846
UPC612079132775
Weight4
Speaker TypePA Horn Speaker
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
