  • Atlas Sound GA-30T 30W Utility Paging Horn Speaker
Atlas Sound
Part #242-848
Atlas Sound
Part #242-848
Model: GA-30T
The GA Series utility horns are perfectly suited for voice paging and music transmission.
  • Dual voltage, knob-adjustable impedance selection for 25/70.7V line connection
  • Multi-function, re-entrant horn loudspeakers offer efficient sound penetration
  • Sturdy construction for long-term indoor and outdoor paging, music, and intercom use
Your Price: $97.99
MSRP: $120.99
Save $23.00 (19%)
The GA Series utility horns are perfectly suited for voice paging and music transmission. Double re-entrant horn construction optimizes loudspeaker output to penetrate ambient sound levels. Includes a combination 25/70.7 volt line transformer with multi-position knob switch for selecting power taps and wiring for an 8 ohm connection. GA Series models are constructed of weather resistant, high-impact plastic for indoor/outdoor installations in high-humidity environments and feature an adjustable surface mount bracket. Gray finish with silver colored hardware.
Specifications: • Power rating: 30 watts • 70.7V Taps: 2, 4, 8, 15, 30 watts • Nominal frequency response: 350-7,500 Hz • Sensitivity: 106 dB 1W/1m • Dimensions: 10" dia. x 12" L x 11" H • Mfg. #GA-30T
BrandAtlas Sound
ModelGA-30T
Part Number242-848
UPC612079132782
Weight5
Speaker TypePA Horn Speaker
MONSTER DEAL
OF THE WEEK
$34.98 EACH
SAVE 22%
Lepai LP-168HA 2.1 2x40W Mini Amplifier + 1x68W Sub Output
