  • Adire Audio ADKO10D2 Koda 10" Subwoofer
8 Questions, 8 Answers or
Adire Audio
Part #294-144
Adire Audio
Part #294-144
Model: ADKO10D2
Adire Audio introduces the Koda subwoofers, bringing XBL2 technology to the masses. The Koda series of subwoofers offer unparalleled displacement for the dollar, using XBL2 motor technology. This allows for a much more linear Bl field throughout the cone travel which results in lower distortion and higher excursion.
  • XBL2 technology for increased excursion and lower distortion
  • Y35 grade magnets for better efficiency
  • Progressive roll spiders for better linearity in all enclosure types
  • Non-pressed cone for added stiffness and lighter weight
  • Carbon fiber dust cap for rugged appearance and added stiffness
  • 15mm Xmax and 250 watt power handling for excellent output capability for the price
Your Price: $274.99
MSRP: $329.99
Save $55.00 (17%)
Order in the next 19 hr 20 min to ship today. Details
Adire Audio ADKO8D2 Koda 8" XBL2 Subwoofer
Unmatched linearity and low distortion and at unbelievable price
The Koda series is back and better than ever for 2023! Adire Audio spent a great deal of time in the design of experiments to further develop our XBL2 enabled woofers bringing what we have learned along the way into our entire flagship XBL2 lineup.
 After countless hours and prototypes we have successfully updated the Koda series which now includes a 250 watt RMS power rating, an in-gap aluminum inductance ring, 2” flat wire copper voice coils, progressive roll spiders and stitched tinsel leads to prevent mechanical noise.
The 2023 Koda features 8awg push pin terminals for easy wiring, non pressed kraft pulp hybrid fiber blend cone body, a multi-layer foam surround and carbon fiber dust cap that keeps the 2023 Koda as rugged as possible for your musical enjoyment for many years to come.
 The addition of the in gap aluminum inductance ring allows the all new 2023 Koda series to dig deep and extend cleaner up into the upper end of the spectrum while not sacrificing any bottom end output.
The utilization of high the grade Y35 magnet keeps motor strength strong and still keeps the 2023 Koda tonally balanced throughout the sonic realm.
The utilization of high the grade Y35 magnet keeps motor strength strong and still keeps the 2023 Koda tonally balanced throughout the sonic realm. The 2023 Koda is definitely an excellent entry for the aspiring audiophile who’s looking to have solid clean output without breaking the bank!
BrandAdire Audio
ModelADKO10D2
Part Number294-144
UPC753459579961
Weight21.05
Nominal Diameter10"
Bolt Circle Diameter10
Power Handling (RMS)250 Watts
Power Handling (MAX)500 Watts
Frequency Response30 to 500Hz
Sensitivity85.79dB 2.83V/1m
Voice Coil Diameter2"
Resonant Frequency (Fs)31.7Hz
DC Resistance (Re)3.44Ω
Mechanical Q (Qms)4.49
Electromagnetic Q (Qes)0.46
Total Q (Qts)0.41
Compliance Equivalent Volume (Vas)1.3ft³
Mechanical Compliance of Suspension (Cms)0.23mm/N
BL Product (BL)12.71T·m
Diaphragm Mass Inc. Airload (Mms)108.83g
Maximum Linear Excursion (Xmax)15mm
Surface Area of Cone (Sd)334.5cm²
Surround MaterialFoam
Overall Outside Diameter10.875"
Baffle Cutout Diameter9.375"
Depth5"
Sealed Volume0.5ft³
Sealed F360.3Hz
Vented Volume1.375ft³
Vented F330.2Hz
