  • ART CX310 2-Way/3-Way Crossover
ART
Part #245-880
ART
Part #245-880
Model: 310
The Model 310 is the perfect addition to any sound reinforcement system. Designed for live sound and fixed-install applications, the 310 employs 4th order (24 dB/octave) Linkwitz-Riley filters for easy interface into any audio system.
Your Price: $229.99
MSRP: $329.99
Save $100.00 (30%)
The Model 310 is the perfect addition to any sound reinforcement system. Designed for live sound and fixed-installation applications, the 310 employs 4th order (24 dB/octave) Linkwitz-Riley filters for easy interface into any audio system. One year manufacturer warranty.
Features: • Input level, high and low output level and crossover frequency rotary controls on each channel • Front panel output mutes for each output • XLR and active balanced 1/4" TRS input and output connectors.
Rugged all steel construction Specifications: • Crossover ranges: (x1) 80 to 920 Hz, (x10) 800 to 9,200 Hz • Dynamic range: > 85 dB • Frequency response: 10 to 20,000 Hz (+0/-1.5 dB) • THD: 0.05% • Signal-to-noise ratio: 118 dB • 1U rack space • Dimensions:1-3/4" H x 19" W x 6-1/2" D • Net weight: 5 lbs.
BrandART
Model310
Part Number245-880
UPC840402011460
Weight7.3
