  • ART CX311 Stereo 2-Way Crossover with Sub Out
ART
Part #245-862
ART
Part #245-862
Model: 311
The ART CX311 crossover may be used as a stereo 2-way crossover network and has the addition of a subwoofer output for low-frequency reinforcement.
  • Stereo 2-way crossover
  • Subwoofer output
  • Fourth-order Linkwitz-Riley filters (24 dB/octave state-variable)
  • Independent high and low output level controls
  • Crossover frequency rotary control (250 Hz to 6 kHz)
  • 30 Hz low cut switch
  • Independent sub output level and frequency control (50 Hz to 250 Hz)
Your Price: $149.99
MSRP: $219.99
Save $70.00 (32%)
Order in the next 10 hr 42 min to ship today. Details
The ART CX311 crossover may be used as a stereo 2-way crossover network and has the addition of a subwoofer output for low-frequency reinforcement. It employs 24 dB/octave state-variable, fourth-order Linkwitz-Riley filters that guarantee properly phased outputs at all frequencies, which is optimal for the proper acoustic summing of common signals from adjacent drivers in the crossover region. Each channel features independent high and low output level controls and a crossover frequency rotary control which covers a wide range (250 Hz to 6 kHz). All three outputs have a 30 Hz low cut switch to eliminate low-end rumble. The subwoofer features an independent output level and rotary control for frequencies in the 50 Hz to 250 Hz range.
Specifications: • Frequency response: 10 Hz - 40 kHz, ±.5 dB • Max input level: +21 dBu • Max output level: +21 dBu • Signal to noise ratio: >95 dB, 20 Hz - 20 kHz, unweighted • THD: <0.01% • Dimensions: 1.75" H x 19" W x 5.5" D • Weight: 4.85 lbs.
BrandART
Model311
Part Number245-862
UPC840402019831
Weight8
