  • 4-Pack 1.5" Black Plastic Caster Wheel Swivel Plate Caster with 55 lb. Load Rating
BUYOUT 4-Pack 1.5" Black Plastic Caster Wheel Swivel Plate Caster with 55 lb. Load Rating
Factory Buyouts
Part #269-684
Factory Buyouts
Part #269-684
These caster work great for food carts, small wooden racks, or almost anything that four screws are able to mount to the bottom of.
  • Durable 4-hole metal plate mounts to almost anything
  • Easy and smooth rolling on carpet or floor
  • Twin wheel plastic caster for support
  • Economical 4-pack
BUYOUT $2.97
MSRP: $10.00
Save $7.03 (70%)
Order in the next 2 hr 39 min to ship today. Details
348In Stock
These caster work great for food carts, small wooden racks, or almost anything that four screws are able to mount to the bottom of. Each wheel handles up to 55 LBS. The square 1.36" x 0.079" (34.5 x 2mm) metal base has four 0.25" x 0.16"(6.35 x 4mm) oval screw holes 0.9" (23mm) apart from center (screws sold separately). The wheels are 1.5" (38.3mm) in diameter and the total height with mounting bracket is 2.03" (51.5mm).
BrandFactory Buyouts
Part Number269-684
UPC848864065472
Unit of MeasurePackages
Weight0.4
Caster TypeSwivel
Wheel Diameter1.5"
