  • 18 Pc Ratchet Tool Set with Double-Ended Aluminum Handle
Part #360-142
Part #360-142
For quick work in small spaces use this 36 teeth, double sided, heavy duty aluminum handle ratchet. It includes steel bits, sockets, and an extension for hard to reach areas.
  • Double sided ratchet for driving screws and bolts without having to change attachments
  • 3-way ratchet with lock position when ratcheting action is not needed
  • Rust resistant, stainless steel screwdriver extension
  • Corrosion resistant heavy duty sockets
  • Magnet in bit holder and ball joint in socket shaft keep attachments secure
  • 36 teeth in the ratchet for moving the handle in small gaps
  • 800 kg/cm of torque for driving screws and bolts
Your Price: $16.98
MSRP: $21.99
Save $5.01 (23%)
Make quick work of a task that requires tightening and loosening, bolts and screws with this double sided ratchet. Just twist the heavy duty aluminum handle to change from a socket wrench to a screwdriver without having to swap attachments. A magnet in the ratchet and extension secures the bits and a ball joint holds the sockets in place. The ratchet's 36 teeth 9" diameter head and 3" L x 0.5" Diameter shaft enables the handle to move back and forth in tight spaces.
This kit uses heavy duty metals to make it last for years to come. Aluminum 7075 makes the handle more durable the other small ratchets. The socket's steel composition is 50BV30 and the bit's is S2. This aids them in holding up to 800 kg/cm of torque that the ratchet can deliver. They are also corrosion resistant and the bit extension's stainless steel material keeps it from rusting. The heavy duty PC/ABS case protects and organizes the pieces when not in use.
Kit includes:
• Handle: 3.9" long double-ended ratchet for 1/4" sockets
• Bit extension: 1.98" L x 0.4" Dia.
• Spline sockets: 4 mm, 5 mm, 6 mm, 8 mm, 10 mm, 13 mm
• Phillips bits: 0, 1, 2, 2, 3
• Slotted bits: 2.0, 3.0, 4.0, 5.0, 6.0
• Case: 4.9" L x 3.4" D x 1.3" H
Part Number360-142
UPC848864044309
Weight0.65
