  • 15V 4A DC Power Supply AC Adapter with 2.1 x 5.5mm Center Positive (+) Plug
Part #120-057
Part #120-057
The 15 VDC regulated AC adapter makes an excellent replacement for those damaged or lost power supplies, and works great for adding power to mini amps and amp boards that require up to 4 amps.
  • Switching power supply keeps voltage consistent
  • 15 VDC @ 4A maxes out the wattage for mini amps and amp boards that handle that much voltage
  • Meets level VI standby efficiency requirements
  • UL listed for safety
  • Handles international AC voltage from 100 - 240 VAC @ 50/60 Hz
Your Price: $17.98
MSRP: $23.99
Save $6.01 (25%)
460In Stock
This switching AC adapter delivers noise free power to your amp boards or powered speakers that require 15 VDC. Turn up the volume and use as much of the 4 amps that you need. Use this adapter with confidence, because it meets all UL safety requirements and has built-in overload protection. When in standby mode, this adapter meets level VI energy saving efficiency requirements.
Don't throw away your portable electronics just because you can't find the original 15 V adapter. This power adapter replaces those portable electronic devices that require 15 V with tip 2.1 mm x 5.5 mm center positive. Its 4A of current energizes high-resolution color screens that portable electronics now use. It also powers the Auvio 6000HTB Sonic Emotion Absolute 3D Bluetooth speaker ((4000438).
Specifications: • Output voltage: 15 V @ 4A • Input voltage: 100-240 VAC @ 50/60 Hz • DC output cord length: 4 ft. with 2.1 mm x 5.5 mm x 10 mm with center positive plug • AC input cord length: 4 ft. • Dimensions: 4.6" L x 2.14" W x 1.33" H.
Part Number120-057
UPC848864044033
Weight0.9
Center/Tip PolarityCenter Positive
Current Capacity4000mA
DC Output Voltage15V
Input Voltage100~240 VAC
Plug Size2.1 x 5.5 mm
