  • 19.5V DC 3.33A AC Power Supply Adapter with 2.1 x 5.5mm Tip + Plug
Part #120-195
Part #120-195
Get more wattage from your amplifier boards that can handle up to 19.5 VDC with this 3.33A AC adapter. Replace your lost or damaged laptop power supplies that require fewer than 90 watts.
  • Standard 2.1 x 5.5 mm tip positive plug
  • 19.5 VDC powers Bluetooth and other amp boards that draw less than 3.33A
  • FCC certified and ETL listed for safety
  • Certified level VI for standby power savings
Your Price: $17.98
MSRP: $23.99
Save $6.01 (25%)
Order in the next 5 hr 51 min to ship today. Details
567In Stock
This 19.5 V AC adapter is perfect for new audio projects requiring more than 12 volts. It has enough amperage to handle boards up to 65 watts. The power supply's output works perfect with Dayton Audio KAB Bluetooth amp boards that are using the lithium battery expansion board KAB-BE.
The ETL listing makes this adapter safe to use and level VI meets US standby efficiency requirements. This adapter comes with a 2.1 x 5.5 mm that plugs into many amplifier boards and all the Dayton Audio LBB series battery boards.
Specifications: • Input voltage: 100-240 VAC • Input current: 2A • Output Voltage: 19.5 VDC • Current output: 3.33A • Power range: 65 watts • Output cord: 4 ft. with 2.1 mm x 5.5 mm center positive plug • AC cord: 4 ft. • Dimensions: 4.75" L x 2" W x 1.19" H.
Part Number120-195
UPC848864066721
Weight0.7
Center/Tip PolarityCenter Positive
Current Capacity3300mA
DC Output Voltage19V
Input Voltage100~240 VAC
Plug Size2.1 x 5.5 mm
