  • 1" Heat Shrink Tubing 2:1 Thin Wall-Black 4 ft.
NEW 1" Heat Shrink Tubing 2:1 Thin Wall-Black 4 ft.
Thermosleeve
Part #080-980
Thermosleeve
Part #080-980
Heat shrinks Thermosleeve's tubing to half of its original size (2:1) and offers an outstanding balance of electrical, physical and chemical properties for a wide variety of applications. Rated for -67 to 275° F (-55 to 125° C) continuous operation.
  • Organize and protect wires with one heat shrink tube
  • UL certified, Halogen-free, flexible, flame retardant heat-shrinkable tubing for versatility and safety
  • Split resistant for long lasting performance
  • Wide temperature range for multiple applications
  • Even a hairdryer shrinks the tubing at a temperature 194° F (90°)
  • Free of Pb, Cd, Hg, Cr+6, PBB and PBDE
NEW $3.49
MSRP: $7.99
Save $4.50 (56%)
Quantity:Qty: 1-24 $3.49/ea
Quantity:Qty: 25+$3.14/ea
Order in the next 10 hr 14 min to ship today. Details
Professional Look and Protection
Heat shrink tubing is a remarkable material that deserves a deeper examination for its versatility and efficiency across various applications. Shrinking to half its original size (2:1) allows it to provide a snug, secure fit over a range of electrical components, making it an essential tool for anyone working with wiring and connections. With a continuous operating temperature rating of -67 to 275° F (-55 to 125° C), this tubing proves itself reliable under demanding conditions, inspiring confidence in its capacity to protect critical components.
Audio Technicians Love It
Not only is it primarily used as shrink-fit electrical insulation over splices and terminations, but its utility extends to lightweight wire harness covering, wire marking, wire bundling, component packaging, and even fire-resistant applications. This broad spectrum of uses showcases the tubing's outstanding balance of electrical, physical, and chemical properties, making it an indispensable resource in both professional and DIY settings.
Built to Last
Moreover, the heat shrink tubing offers unique qualities such as split resistance and mechanical toughness, ensuring longevity and durability in various environments. Its ability to resist cold flow means that it holds its shape and protective qualities over time, maintaining a robust defense against potential damage. The fact that it can be easily marked adds a layer of convenience and organization, particularly in complex wiring setups.
In light of these attributes, it's clear that heat shrink tubing is more than just a simple accessory—it's a powerful ally in electrical insulation and protection. For those engaged in electrical work, embracing the use of heat shrink tubing not only enhances the quality of your projects but also contributes to safer and more reliable electrical systems. Thus, I wholeheartedly encourage you to incorporate this exceptional material into your toolkit, as it is sure to elevate your work to a higher standard of excellence.
Note: All 4-foot lengths of heat shrink tubing is folded for shipping. It may arrive with kinks, but don’t worry. When heat is applied the kinks disappear.
Specifications: • UL Recognized at 600 volts at -55 to 257° F (125° C) • UL File No. E-180908 • Shrink temperature: 90° • Radial shrinking rating: ≥ 50 • Tensile Strength (MPa): ≥ 10.4 • Flammability rating: VW-1 • Concentricity (%): ≥ 65.
BrandThermosleeve
ModelHST01BK4
Part Number080-980
UPC848864080147
Weight0.01
ColorBlack
Nominal Preshrink I.D.1" - 24mm
Shrink Ratio2:1
