  • Dayton Audio Stereo / Bridgeable Amplifier 150 Watt APA150
Dayton Audio
Part #300-812
Dayton Audio
Part #300-812
Model: APA150
Dayton Audio's versatile APA150 power amplifier delivers 75 watts per channel in its full-range stereo configuration, or 150 watts into 8 ohms when in bridge-mono mode. A built-in, switchable low-pass filter also makes the APA150 a great subwoofer amp!
  • Class A/B topology for low distortion and ultimate reliability
  • Virtually noise-free fan operation for near field applications
  • High current, discrete output transistors that run cool and quiet
  • Adjustable 50 - 150 Hz low pass crossover gives you the room control you need
  • Ultra linear frequency response from 10 Hz to 40 kHz makes this a great amp for high-resolution playback or acoustic measuring
  • With a Dayton Audio 5 year warranty, it’s more than a guarantee, it’s a promise
  • Sleek modern design looks good and sounds great
Your Price: $199.98
MSRP: $227.74
Save $27.76 (12%)
Order in the next 3 hr 2 min to ship today. Details
Dayton Audio APA150 150W Stereo / Bridgeable Amplifier
The Only Amplifier You'll Ever Need
Amplifiers today need to be multi-faceted to keep up with the task at hand, and versatility is the foundation upon which the Dayton Audio APA150 is built. When configured in stereo mode, 75 watts of amplification is provided to a pair of speakers for stereo or surround playback. Select bridge-mono mode and the APA150 is ready to power a center channel speaker, or a subwoofer/tactile transducer with 150 watts when used with the on-board low pass filter. Full-range line-level outputs allow for daisy chaining amplifiers for a multi-room whole house audio system or for bi-amp applications. The APA150's smaller chassis consumes less space than conventional amplifiers, making placement options virtually limitless.
New Dog, Old Tricks
Stable class A/B topology provides clean, low distortion audio. Standard features of the APA150 include high current, discrete power transistors (used in premium amp designs), a hefty toroidal power supply transformer, low-noise forced air cooling, and complete protection against electrical shorting and thermal overload.
Total Integration
The APA150 was designed for heavy duty use, including subwoofers. An 18dB/Oct low-pass filter can be set from 50Hz to 150Hz or run it in full range for higher powered speakers!
The APA150 has the ability to bridge the stereo outputs to combine both channels for extra power with a single mono/stereo switch.
When the APA150 detects signal at its input, it can automatically turn itself on. Once the music has stopped playing, the APA150 will turn itself off automatically to save power. No fuss and no more reaching over your expensive equipment!
Full Specifications:
  • Maximum Output Power: 2x 75 watts RMS @ 4ohms, 1x 150 watts RMS @ 8ohms
  • THD: <0.01%
  • Frequency Response: 10 Hz - 40kHz +/- 1.5dB
  • SNR: >100dB Unweighted
  • Input Sensitivity: 1V
  • Line Input Connectors: RCA
  • Line Output Connectors: RCA
  • Low Pass Crossover Range: 50 Hz - 150 Hz
  • Line Input Impedance: 47kOhm
  • Power Input Voltage Range: 120 - 240 VAC
  • Dimensions (W x H x D): 5.6" H x 5.7" W x 12.8" D
  • Weight: 13 lbs.
ModelAPA150
Part Number300-812
UPC844632061523
Weight13
Weight Range10 to 19 lbs.
