  • Dayton Audio APA102BT Class D Stereo 60 WPC Bluetooth Amplifier
Dayton Audio
Part #300-593
Dayton Audio
Part #300-593
Model: APA102BT
Connect with the Dayton Audio APA102BT amplifier and enjoy the convenience of Bluetooth, auto-on, and auto-source switching technology that makes playing your favorite music a breeze. Use this affordable, versatile amp when more power is needed in a multi-zone system, or in a powerful, audiophile-grade stereo hi-fi setup.
  • Bluetooth 4.2 with aptX technology for wireless Hi-Fi listening
  • Dual stereo RCA line level inputs switch sources automatically
  • Convenient signal sensing power on and trigger modes save power when not in use
  • A/B speaker selector simplifies connectivity
  • 5-way binding posts on both sets of L/R speaker outputs
  • With a Dayton Audio 5 year warranty, it’s more than a guarantee, it’s a promise
Your Price: $184.98
MSRP: $209.99
Save $25.01 (12%)
The Dayton Audio APA102BT high fidelity power amplifier switches sources and powers on (in auto-on mode) automatically when a source signal is detected. Bluetooth 4.2 with aptX, two line input sources, two-channels, and Class D topology make Dayton Audio's APA102BT amplifier the heavyweight in its class. The APA102BT features two pairs of RCA line level inputs and a loop-out from the second source to feed additional zones, receivers, or other devices. Use the APA102BT for additional power when connected to a multi-zone audio system, or by itself to power a stereo speaker system.
The APA102BT is rated at 80 watts RMS per channel into 4 ohms, and 60 watts RMS per channel into 8 ohms. In bridged mono mode, both amplifier channels are combined for high-power monaural output. The amplifier is rated at 160 watts RMS into a single 8 ohm load when bridged. Each amplifier output channel incorporates robust protection circuitry for reliability and safety. Rack ears are included.
Specifications: • Output power: 2 x 60 watts RMS into 8 ohms, 2 x 80 watts RMS into 4 ohms, 1 x 160 watts RMS into 8 ohms (minimum impedance) bridged mono • Bluetooth version: 4.2 with aptX • DAC sample rate: 24-bit/96 kHz •Total harmonic distortion: <1.0% @ 1 kHz • Signal to noise ratio: 88 dB, A-weighted • Frequency response: 10-30,000 Hz • Input sensitivity: 600 mV • Power: 120 VAC, 60 Hz, 200 watt maximum • Amplifier chip: TDA8950TH • Dimensions: 16.9" W x 7.65" D x 2.15" H.
With a Dayton Audio 5 year warranty, it’s more than a guarantee, it’s a promise. We stand behind our products and our warranty is a demonstration of our commitment to quality and reliability.
ModelAPA102BT
Part Number300-593
UPC848864056234
Weight6.25
Power (RMS/Channel 8 ohms)51 - 100 Watts
Weight Range< 10 lbs.
Special FeaturesBluetooth
