All the Speakers you Need
Dayton Audio’s HTS-1200B home theater system is designed to be unobtrusive while providing excellent clarity and detail. The smooth blending of their optimized long-excursion woofers and poly dome tweeters is the key to their outstanding performance. Consistent voicing is presented by the satellite and center channel speakers, and they work great with Dayton Audio subwoofers. Contemporary black finish styling allow them to blend in with any decor, while the weather-resistant design means they can be used indoors or out. Included brackets and rubber feet facilitate stand-mounted, wall-mounted, or free standing operation. Includes speaker wire (5 x 12 ft. lengths of 2 x 22 AWG construction), four satellite speakers, and one center channel.
The Dayton Audio SUB-800 8" powered subwoofer system is the perfect addition to any home theater system. This powered sub features a bottom-firing, flared port, bass reflex design for reduced port noise and increased bass response. It also utilizes a long-throw 8" woofer and up to 80 watts of house-shaking power.
The amplifier features high and low level inputs and high level outputs, a phase switch, independent volume control, an auto on/off switch (activated by an input signal) and a variable 12 dB electronic low pass filter. This compact sub is finished in an unobtrusive black vinyl that will complement any decor.
Receiver Specifications:
• Channels: 5.1
• Rated output power: 100 Watts (8 ohms, 1 kHz, 1 channel driven, 0.9%THD), 70 watts (8 ohms, 20 Hz - 20 kHz, 2 channels driven, 0.09%THD)
• Maximum effective output: 145 watts (6 ohms, 1 kHz, 1 channel driven, 10% THD)(JEITA)
• Surround sound processing: CINEMA DSP, Dialog Level Adjustment, SILENT CINEMA / Virtual CINEMA DSP, Dolby TrueHD, Dolby Digital Plus, DTS-HD Master Audio
• Audio features: Compressed Music Enhancer, YPAO Sound Optimization, Adaptive Dynamic Range Control
• DAC: 24-bit/192 kHz
• Video features: 4K Ultra HD pass-through and upscaling (4K / 60p, 4:4:4), HDMI 3D pass-through, HDMI Audio Return Channel, HDMI upscaling
• HDMI in / out: 4 / 1 (HDCP 2.2, HDR10, Dolby Vision, HLG, and BT.2020 compatible)
• Digital audio in / out optical: 1 / 0
• Digital audio in / out coaxial: 2 / 0
• Analog audio in / out: 3 (front 1) / 0
• Composite video in / out: 3 / 1
• Preout: Subwoofer
• Connectivity: Bluetooth
• Dimensions: 17.13" W x 6.38" H x 12.38" D
SAT Satellite Speaker Specifications: • Woofer: 3-3/4" poly with rubber surround • Tweeter: 5/8" polycarbonate ferrofluid cooled • Power handling: 50 watts RMS/80 watts max • Impedance: 8 ohms • Frequency response: 100-20,000 Hz • SPL: 87 dB 1W/1m • Dimensions: 7-1/2" H x 4-1/2" W x 5-1/4" D.
CCS-33 Center Channel Specifications: • Woofer: Dual 3-3/4" poly with rubber surrounds • Tweeter: 5/8" polycarbonate ferrofluid cooled • Supertweeter: 5/8" piezo • Power handling: 80 watts RMS/120 watts max • Impedance: 8 ohms • Frequency response: 100-20,000 Hz • SPL: 87 dB 1W/1m • Dimensions: 4-1/2" H x 12-1/2" W x 6" D.
Sub Specifications: • Power output: 80 watts RMS • Frequency response: 40-140 Hz • Box design: Ported • Inputs: RCA line level & speaker level • Outputs: Speaker level • Crossover frequency control: Continuously variable from 40 Hz to 140 Hz @ 12 dB/octave • Phase switch • Auto on/off • Power requirements: 120 VAC, 60 Hz • Dimensions (including plastic feet): 12-3/4" H x 12-3/16" W x 14-3/8" D.
