  • XVIVE U3 2.4GHz Wireless Microphone System with XLR Transmitter and XLR Receiver
CLEARANCE XVIVE U3 2.4GHz Wireless Microphone System with XLR Transmitter and XLR Receiver
8 Questions, 8 Answers or
XVIVE
Part #245-962
XVIVE
Part #245-962
Model: U3
The Xvive U3 wireless mic system features digital wireless technology that delivers incredible audio quality, simple setup, and is extremely reliable for any studio, live sound, presentation, or theater application. With the U3 you can turn any dynamic mic into a wireless system. Simply plug the transmitter and receiver into their respective input or output and you now have complete wireless functionality.
  • Operates at 2.4 GHz ISM band for crystal clear broadcasting ensuring the integrity of your signal on stage
  • Works with any dynamic mic as well as battery-powered condensers
  • overs an expansive 90 feet of range without any signal dropout
  • Great audio detail with only 5 ms of latency while simultaneously broadcasting on 6 channels
  • Li-ion batteries last up to 5 hours per charge to ensure enough battery life for gigs and rehearsals
Xvive U3 mic system features digital wireless technology that delivers incredible audio quality, simple setup, and is extremely reliable for any studio, live sound, presentation, or theater application. It delivers a full 20-20,000 Hz frequency response, so you’ll hear your audio in great detail with only 5 ms of latency. This wireless system operates at 2.4 GHz ISM band for crystal clear broadcasting ensuring the integrity of your signal on stage and covers 90 feet of range without any signal dropout. The Li-ion batteries last up to 5 hours per charge. The chassis is made out of a durable ABS plastic that can withstand the rigors of touring and the harshest of climates. This wireless is a perfect fit for any mixer thanks to its simplistic, and compact design. So, go wireless with the Xvive U3 system.
Stable and Flexible
Designed for professional dynamic microphones, the U3 has a recording-level sound transmission quality, provides stable and reliable wireless transmission. The flexible and portable wireless solution that allows you to use your favorite microphones with different frequency characteristics. It is suitable for recording studios, theatrical, speaking and outdoor use. p>
Plug and Perform
The U3 is easy to operate with a balanced XLR interface, you just need to turn on the power. Reduce a lot of tedious settings, allowing you to enjoy the fun and convenience of wireless.
Small Yet Powerful
In such a compact space, built-in lithium-ion batteries provide you with five hours of usage and a stable wireless technology. A durable metal case can be adapted to various situations.
2.4 GHz Wireless Freedom
Xvive U3 digital wireless systems broadcast in the 2.4 GHz band, which successfully avoids interference caused by TV stations, public safety broadcasts, cell phone towers, and other high-powered sources.
Specifications: • Range: Up to 90 feet line-of-sight • Latency: > 5ms • Frequency response: 20 - 20,000 Hz • SNR: 110 dB • Dynamic range: >110 dB A weighted • Operating band: 2.4 GHz ISM worldwide • Sample rate: 24-bit/48 kHz uncompressed digital transmission • Battery: Li-Ion • Battery life: 5 hours.
BrandXVIVE
ModelU3
Part Number245-962
Weight0.95
