Wavecor WF182BD10 7" Balanced Drive Paper/Glass Fiber Cone Mid-Woofer 8 Ohm
Wavecor
Part #298-1206
Wavecor
Part #298-1206
Model: WF182BD10
The Wavecor WF182WA10 is a 7" paper/glass fiber cone midwoofer that utilizes balanced drive technology and is designed for demanding bass and midrange applications. The WF182WA10 is a very good choices for either 2 or 3-way speaker systems.
- Vented voice coil former for reduced distortion and compression
- Balanced Drive motor structure for optimal drive force symmetry resulting in largely reduced 2nd order harmonic distortion
- Built-in aluminum field-stabilizing ring for reduced high-level distortion
- Large motor structure for better control and power handling
- Copper cap on center pole to reduce voice coil inductance and to minimize variations in voice coil inductance as a function of voice coil position
- New vented chassis for lower air flow speed reducing audible distortion
- Progressive suspension with specially designed conex spider for long durability under extreme operating conditions
