  • Wavecor WF168WA06 6-1/2" Glass Fiber Cone Mid-Woofer 8 Ohm
Wavecor
Part #298-1194
Wavecor
Part #298-1194
Model: WF168WA06
The Wavecor WF168WA06 is a 6-1/2" glass fiber cone midwoofer that is designed for demanding bass and midrange applications. The WF168WA06 is a very good choices for 2-way speaker systems or even as midrange in 3-way systems.
  • Vented voice coil former for reduced distortion and compression
  • Gold plated terminals to prevent oxidation, for long-term reliable connection
  • Built-in aluminum field-stabilizing ring for reduced high-level distortion
  • Large motor structure for better control and power handling
  • Black magnet parts for better heat transfer to increase power handling
  • New vented chassis for lower air flow speed reducing audible distortion
  • Progressive suspension with specially designed conex spider for long durability under extreme operating conditions
Your Price: $77.00
Order in the next 12 hr 39 min to ship today. Details
The Wavecor WF168WA06 is a 6-1/2" glass fiber cone midwoofer that is designed for demanding bass and midrange applications. This driver is powered by a large magnet structure that ensures good efficiency. The WF168WA06 is a very good choices for 2-way speaker systems or even as midrange in 3-way systems.
The large motor system with 1-1/4" voice coil diameter and large magnet for better control, power handling, and efficiency. The optimized glass fiber cone ensures wide bandwidth and low distortion. Distortion is further reduced by efficient venting of the chassis and voice coil former.
BrandWavecor
ModelWF168WA06
Part Number298-1194
UPC848864054988
Weight2.65
Nominal Diameter6-1/2"
Power Handling (RMS)60 Watts
Power Handling (MAX)120 Watts
Frequency Response60 to 3,000Hz
Sensitivity88dB 2.83V/1m
Voice Coil Diameter1.26"
Resonant Frequency (Fs)41Hz
DC Resistance (Re)6.4Ω
Voice Coil Inductance (Le)0.4mH
Mechanical Q (Qms)7
Electromagnetic Q (Qes)0.54
Total Q (Qts)0.5
Compliance Equivalent Volume (Vas)0.98ft³
Mechanical Compliance of Suspension (Cms)1.14mm/N
BL Product (BL)6.4T·m
Diaphragm Mass Inc. Airload (Mms)13.4g
Surface Area of Cone (Sd)131cm²
Cone MaterialFiberglass
Voice Coil FormerFiberglass
Overall Outside Diameter6.61"
Baffle Cutout Diameter5.63"
Depth2.87"
Sealed Volume0.4ft³
Sealed F367.6Hz
Vented Volume0.8ft³
Vented F342.5Hz
