  • Wavecor WF152BD08 6" Balanced Drive Paper/Glass Fiber Cone Mid-Woofer with Truncated Frame 8 Ohm
CLEARANCE Wavecor WF152BD08 6" Balanced Drive Paper/Glass Fiber Cone Mid-Woofer with Truncated Frame 8 Ohm
1 Question, 2 Answers or
Wavecor
Part #298-1182
Wavecor
Part #298-1182
Model: WF152BD08
The Wavecor WF152BD08 is a 6" paper/glass fiber cone midwoofer with a truncated frame that utilizes balanced drive technology and is designed for demanding bass and midrange applications. The WF152BD08 is a very good choices for 2-way speaker systems or even as midrange in 3-way systems.
  • Balanced Drive motor structure for optimal drive force symmetry resulting in largely reduced even order harmonic distortion
  • Copper cap on center pole to reduce voice coil inductance and to minimize variations in voice coil inductance as a function of voice coil position
  • Built-in aluminum field-stabilizing ring for reduced high-level distortion
  • Large motor structure for better control and power handling
  • Low-loss suspension (high Qm) for better reproduction of details and dynamics
  • Rigid die cast aluminum chassis with extensive venting for lower air flow speed reducing audible distortion
  • Progressive suspension with specially designed conex spider for long durability under extreme operating conditions
CLEARANCE $126.00
Order in the next 4 hr 26 min to ship today. Details
Only 1 In Stock
The Wavecor WF152BD08 is a 6" paper/glass fiber cone midwoofer with a truncated frame that is designed for demanding bass and midrange applications. This driver is powered by a large magnet structure that ensures good efficiency. The WF152BD08 is a very good choices for 2-way speaker systems or even as midrange in 3-way systems.
The large motor system with 1-1/4" voice coil diameter and large magnet for better control, power handling, and efficiency. The optimized paper/glass fiber cone ensures wide bandwidth and low distortion. Distortion is further reduced by efficient venting of the chassis and voice coil former.
BrandWavecor
ModelWF152BD08
Part Number298-1182
UPC848864054926
Weight3.55
Nominal Diameter6"
Power Handling (RMS)70 Watts
Power Handling (MAX)140 Watts
Frequency Response70 to 3,000Hz
Sensitivity87dB 2.83V/1m
Voice Coil Diameter1.26"
Resonant Frequency (Fs)46Hz
DC Resistance (Re)3.2Ω
Voice Coil Inductance (Le)0.11mH
Mechanical Q (Qms)8
Electromagnetic Q (Qes)0.36
Total Q (Qts)0.35
Compliance Equivalent Volume (Vas)0.45ft³
Mechanical Compliance of Suspension (Cms)0.94mm/N
BL Product (BL)8T·m
Diaphragm Mass Inc. Airload (Mms)12.8g
Maximum Linear Excursion (Xmax)4.5mm
Surface Area of Cone (Sd)93cm²
Voice Coil FormerFiberglass
Overall Outside Diameter5.51"
Baffle Cutout Diameter5.04"
Depth2.95"
Sealed Volume0.12ft³
Sealed F3104Hz
Vented Volume0.28ft³
Vented F350.8Hz
