  • Wavecor WF132TU02 5-1/4" Paper Cone Mid-Woofer 4 Ohm
CLEARANCE Wavecor WF132TU02 5-1/4" Paper Cone Mid-Woofer 4 Ohm
2 Questions, 3 Answers or
Wavecor
Part #298-1162
Wavecor
Part #298-1162
Model: WF132TU02
The Wavecor WF132TU02 is a 5-1/4" paper cone midwoofer that is designed for demanding bass and midrange applications. This driver is powered by a large magnet structure that ensures good efficiency. The WF132TU02 is an ideal choice for car audio applications.
  • Long linear stroke motor for reduced distortion at high levels
  • Gold plated terminals to prevent oxidation for long-term reliable connection - important in a car environment
  • Built-in aluminum field-stabilizing ring for reduced high-level distortion
  • Rigid die cast aluminum chassis with extensive venting for lower air flow speed reducing audible distortion
  • Vented voice coil former for reduced distortion and compression
  • Vented center pole with dual flares for reduced noise level at large cone excursions
  • Progressive suspension with specially designed conex spider for long durability under extreme operating conditions
CLEARANCE $105.00
Order in the next 4 hr 26 min to ship today. Details
Only 1 In Stock
The large motor system with 1-1/4” voice coil diameter and large 90 mm magnet for better control, power handling, and efficiency. The optimized paper cone ensures wide bandwidth and low distortion. Distortion is further reduced by efficient venting of chassis and voice coil. The Wavecor WF132TU02 is an obvious choice for 2-way high-end car speaker systems.
BrandWavecor
ModelWF132TU02
Part Number298-1162
UPC848864054834
Weight2.75
Nominal Diameter5-1/4"
Power Handling (RMS)55 Watts
Power Handling (MAX)110 Watts
Frequency Response62 to 4,000Hz
Sensitivity90dB 2.83V/1m
Voice Coil Diameter1.26"
Resonant Frequency (Fs)62Hz
DC Resistance (Re)3.2Ω
Voice Coil Inductance (Le)0.23mH
Mechanical Q (Qms)8
Electromagnetic Q (Qes)0.46
Total Q (Qts)0.44
Compliance Equivalent Volume (Vas)0.32ft³
Mechanical Compliance of Suspension (Cms)0.66mm/N
BL Product (BL)5.2T·m
Diaphragm Mass Inc. Airload (Mms)10g
Surface Area of Cone (Sd)95cm²
Cone MaterialPaper
Voice Coil FormerFiberglass
Overall Outside Diameter5.90"
Baffle Cutout Diameter4.72"
Depth2.38"
Sealed Volume0.14ft³
Sealed F3111.9Hz
Vented Volume0.35ft³
Vented F358Hz
