Wavecor WF118WA02 4-1/2" Paper Cone Mid-Woofer 8 Ohm
Wavecor
Part #298-1134
Wavecor
Part #298-1134
Model: WF118WA02
The Wavecor WF118WA02 is a 4-1/2" paper cone midwoofer designed for demanding bass and midrange applications. It works equally well for high-end hi-fi, high quality home theater systems, and multimedia projects. The WF118WA02 is an ideal choice for a compact 2-way speaker design as a midwoofer.
- Aluminum field-stabilizing ring inside magnet assembly for reduced distortion at high levels
- Vented chassis for lower air flow speed reducing audible distortion
- Voice coil wound with copper clad aluminum wire for higher efficiency and better dynamics
- Large motor system with 1-1/4” voice coil diameter and 85mm magnet for better control and efficiency
- Progressive suspension with specially designed conex spider for long durability under extreme operating conditions
- Gold plated terminals to prevent oxidation and ensure long-term reliable connection
- Long linear stroke motor for reduced distortion at high levels
