Wavecor SW259WA02 10-1/4" Aluminum Cone Subwoofer 8 Ohm
Wavecor
Part #298-1070
Wavecor
Part #298-1070
Model: SW259WA02
The Wavecor SW259WA02 is a 10-1/4" aluminum cone subwoofer that was designed specifically for high performance subwoofer applications where sound quality and low distortion are the priorities. The extensive venting on the aluminum frame allows for optimal cooling.
- Two internally built-in aluminum rings for stabilizing the magnetic field leading to lower high-level distortion
- Very rigid aluminum cone to ensure piston motion at high levels and for better heat transfer at high continuous power levels
- Low-loss suspension (high Qm) for better reproduction of details and dynamics
- New reinforced die cast aluminum chassis with optimal ventilation and increased stroke
- Large motor with 2" voice coil diameter for better control and power handling
- 4-layer voice coil for increased control and better small-cabinet performance
- Conex spider for better durability under extreme conditions
Your Price: $279.00
We'll send you an email when Wavecor SW259WA02 10-1/4" Aluminum Cone Subwoofer 8 Ohm is back in stock or available for preorder.
Advertised price subject to change due to tariff uncertainty
Alert Me When AvailableFree Shipping available on orders over $99.00 in the US. Details
