WBT Nextgen RCA Socket Gold Plated White
Out of Stock
We'll send you an email when WBT Nextgen RCA Socket Gold Plated White is back in stock or available for preorder.
Out of Stock
The Nextgen™ (Topline) RCA socket is the latest addition to the WBT line of products. The heart of the Nextgen™ design is the central contact unit built from the plus and minus conductors. The positive pole features a spring loaded double prism contact, while the negative pole utilizes a patented double-wave contact. The conductor material is made of pure copper and plated in nickel free gold to ensure the highest level of conductivity. This connector also features torsion-proof mounting from the outside using a three-hole counter nut. Available colors: Red, White, Black, Green, Blue, Yellow.
Specifications: • Contact plating: gold • Sold per: each • Transmission bandwidth: 1 GHz (eddy current free) • Characteristic impedance: 75 ohms • Insulation: Teflon™ • Termination style: solder • Mounting panel thickness: up to 0.17" • Dimensions: 0.63" x 1.37"
Product Details | |
Brand | WBT |
Model | WBT0210CUW |
Part Number | 093-626 |
UPC | 726441936264 |
Unit of Measure | Each |
Weight | 0.1 |
Product Specifications | |
Gender | Female / Jack |
Mounting Type | Chassis / Panel Mount |
